MFD issues on '04/'05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Jun 19, 2007.
  1. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    MFD removed - Pix!
    MFD removed. Wasn't quite as bad as I expected, but the instructions online don't mention the connector tabs for the power button and park button. Depress the tabs, and the connectors slide right out.
    Any recommendations as to audio/video input add-ons when I re-install the fixed unit (weeks from now)? I have an iPod/iPhone and it annoys me that I can't plug it in (except through a cassette adapter).
    P.S. As you can see from the pix, I do have an INFO button.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Re: MFD issues on '04/'05 Prius
    Not on my 05.
  3. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    I DIDNT read through this entire thread, but let me explain my "woes" with my 08.
    The system has "rebooted" itself for the total of three times now. Everytime it has rebooted itself, all my memory locations disappeared and the region always goes to somewhere in the mideast. I believe region 6 or 7. I'm in sunny socal, region 2.
    The 2nd time it rebooted, it literally said, NO NOT POWER DOWN, system rebooting. Sort of a dark threat?
    So, since then, about 4 months passed by, no problems until today, the system rebooted itself again. It went from my dual screen to single, it had the system oil change screen and gave me the option of saying, do not ever show this again.
    INTERESTING thing, is that my HOME locations, two of which was inputted, never disappeared, ONLY the places visited on my navi. Now, being a real estate broker, I use the navigation quite a bit. So manually inputting all these addresses again is always a pain.
    HERE's my question..........is my system failing? is it on the way out? should i be concerned? is it just having an electrical hiccup? How worried should i be? Any thoughts?
    Many thanks in advance.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Have you checked your 12 volt battery voltage? Procedure at http://priuschat.com/forums/newbie-...g-mpgs-dropping-test-battery.html#post1020264.
    Interestingly, you're the 2nd 08 guy I've seen recently reporting that type of problem. See http://priuschat.com/forums/gen-ii-prius-main-forum/80307-navigation-problems.html. I wonder if there's a more widespread prob on the 08s and whether a TSB will be issued, if it hasn't already.
  5. Genoz World
    797
    22
    La Canada
    Thanks for the link, CWERDNA.
    anyone else for some help? I drive my prius everyday, lots of miles, my mpg is fine, so I doubt the 12v batt is the culprit.
  6. Politburo
    Politburo Active Member
    971
    208
    You should not assume the 12v is fine. That leads to a lot of wasted time and money.
  7. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    I wonder if you could just hook up a big honkin' 12V battery in parallel with the original as a temporary means of assuring clean 12V power? Probably too many issues (e.g., effect on charging system, nature of original battery's fault(s), BH12VB flying through the air following collision, etc.), but it's appealing.
  8. Genoz World
    797
    22
    La Canada
    OK. was there a test that i can do punching in a series of buttons on the MFD itself to test the battery? I recall some procedure that I read here before, but I dont remember.
  9. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Yeah, look at post #1 in the thread linked to in post #304 in this thread. Right there in black and white.
  10. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    So, I've been driving without the multifunction display for about 10 days now... and it's MUCH more pleasant with no MFD at all than with a defective one. The radio no longer shuts off randomly, and the air conditioning is consistent.
    In the meantime, AutoBeYours has already received, fixed, and shipped the unit back to me (across the border). I'm anxious to receive it obviously, but not as anxious as I originally guessed I'd be. Driving without the MFD is fine.
  11. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    Shipping of the fixed MFD from AutoBeYours.com back to Canada took about a week via USPS from Indiana. Not bad, especially since shipping to Canada was included in his price. I luckily didn't have to pay any brokerage fee or taxes either.
    I installed it... and it said "Please check system". Ouch. Then I unplugged all the cables and reseated their plugs and everything worked perfectly the second time around. Whew! I'll use it a week before declaring it fully fixed, but so far so good.
    BTW, since I had the dash open anyway, I used the opportunity to hide my GPS power cable behind the dash. I have the GPS mounted on the windshield at the bottom left on the driver's side. Obviously that meant running a long wire all the way from the passenger's side, since that's where the 12V plug is. I had previous just taped it to the underside of the dash. Now I have it behind the plastic cover at the front of the "bump" between the two front seats, behind the dash under the steering wheel, and then exiting from the left side of the column of the steering wheel.
    Too bad the cable weren't longer. If it were, then I could run the wire all the way to the left behind the dash, and then up to the left of the left-most vent.
  12. mfa-prius
    299
    46
    Hansville, WA
  13. Phaedrus441
    Phaedrus441 Junior Member
    Charleston, SC
    Hi guys, I've posted a new thread about this, but anybody know if having a lockpick aggravates the problem? My MFDs got all the symptoms, and I wonder if the lockpick, which I've had for 8 months, has strained the connectors or something...
  14. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
  15. hill
    9,013
    Ours (2004) has run for many years, problem free. We had our MFD replaced under the extended warrany, as the original failed at 36,000 miles PLUS. Just like the ol' saying goesl
  16. mfa-prius
    299
    46
    Hansville, WA
    Too far out of the field of view for me.
  17. peterlts
    peterlts New Member
    Sydney
    Hi guys.
    I only joined the forum to publicly express my eternal thanks and gratitude for the magnificent work and solution to the MFD "External Display Not Connected" issue on the Toyota MFD.
    I followed the Hobbit fix 100% and the previously intermittent display in my Australian Toyota Kluger (Highlander in the US) is now in Tip Top condition!
    I tried to solder it but my tip was too big so I rang a local electronics repair place and they charged me $20 to reflow the connector.
    The entire removal, repair & refit was done in about 1 hour and for just $20! Wow!
    Again, THANKYOU Hobbit!!!! You saved me thousands of dollars and a lot of frustration.
    XOX
  18. minerva66
    minerva66 New Member
    CA
    The MFD in my 2006 Prius has been failing (first intermittently, now permanently). When I try to take action by touching the screen, none of the touches are recognized. I've been stuck on the nav screen for about a month until I read through all 32 pages here last night and realized I could probably get out of that screen by hitting the Info button on the steering wheel (never noticed that there before, but have been using the other controls on the steering wheel for climate, audio, etc.).
    Anyway, this morning I tried the Info button on the steering wheel and it got me back to the main screen, and I could toggle back and forth between the energy consumption and other screen. So given that, and the fact that I have a 2006, any thoughts about what is going on with my MFD and why it no longer recognizes touches on the screen? It doesn't sound like I have the pin 60 issue, could it instead just be a fuse? Thanks in advance.
  19. Patrick Wong
    18,210
    6,517
    No, a fuse would not cause the issue where the screen doesn't respond to your touch. Although you may not have the "pin 60" issue, you still have an MFD problem; and the solution would be to replace it.
  20. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Talk to Steve in Indiana at:
    Plug In Hybrid Electric Vehicle PHEV
    He is likely to have a tested MFD from a salvaged Prius that would fit your Prius at a reasonable price (~$500). The instructions for removing an MFD (and reinstalling one) are linked on his site.
    JeffD
