MFD issues on '04/'05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Jun 19, 2007.
  1. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can get it fixed at www.autobeyours.com. Steve in southern Indiana is a good guy and very Gen2 knowledgeable.
    JeffD
  2. Zachrey
    Zachrey New Member
    Taos NM
    MASSIVE THANKS TO YOU FOR ENABLING ME TO FIX MY 2004 PRIUS MFD!!!
    I pulled the unit out and found not only pin 60 had a hairline crack but at least ten others on that same side and end of the connector! Praise Yah, I had a stereo-microscope and could see the hairline cracks on the solder joints. Your persistence in solving this problem is LEGENDARY!! I would've thrown my hands up in the air a long time ago!
  3. Mozencrath
    Mozencrath Junior Member
    50
    So what exactly is the issue then with the 06 through 09 screens? This is unclear. On the 04 and 05 its a solder joint but..06 09?
