MFD Malfunction - BLANK SCREEN
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by canuckican, May 30, 2006.
  1. richard schumacher
    7,683
    1,066
    United States
    Press the DISPLAY button, then:
    1. see whether the on-screen brightness control is at minimum
    2. if there is an on-screen DISPLAY ON button, toggle it so that it reads DISPLAY OFF.
    To prevent unintended commands clean the MFD only with the car OFF.
  2. bseifert
    bseifert New Member
    Sacramento
    I tried that but it did not work.
  3. richard schumacher
    7,683
    1,066
    United States
    Bummer. Please let us know what the dealer service tech finds.
  4. RunnersHigh
    RunnersHigh New Member
    Seal Beach, CA
    WHAT WAS THE TECHNICAL SERVICE BULLETIN YOU QUOTED TO BE ABLE TO GET THE REPAIR FOR FREE? I'M EXPERIENCING THE SAME PROBLEM IN MY 07 PRIUS (BLANK SCREEN BUT OCCASIONALLY IT'LL FLICKER AND SEEM TO WANT TO COME BACK TO LIFE, BUT MAX FOR MAYBE 2 MINUTES) AND AM STUCK WITH EITHER HAVING THE DEALER DO IT (THEY QUOTED $7K TO DO A NEW REPLACEMENT, $1,100 IF YOU SEND YOUR EXISTING MFD BACK) OR BUYING A REFURBISHED ONE AND HAVING THEM INSTALL-NOT EVEN SURE THAT WOULD FIX IT. I'D LOVE TO BE ABLE TO REFERENCE THE RECALL TO DO IT FOR FREE. THANKS FOR THE HELP IN ADVANCE!
  5. Mike500
    Mike500 Senior Member
    2,593
    767
  6. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The MFD and the "Combination Meter" are two different units. The MFD is the large, almost square, touchscreen that provides access to many Prius functions (and is prone to problems like yours). The extended warranty is on the combination meter (which also is prone to problems). If you are having MFD problems call Steve at Prius hybrids sales and service Scottsburg Indiana who repairs them in southern Indiana.
    JeffD
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . I remember people replacing these screens themselves, with refurbished or new. in fact the leading tech expert looked at his and found a open solder joint. At the very least, reboot, that is disconnect the 12v neg lead for a few secoonds and then reconnect. Your 12 V is good? The easiest way to get the 12 V checked, is just take it to a Battery shop, like Batteries Plus. They have good testers.
  8. Cyndi
    Cyndi Junior Member
    Clovis, CA
    My screen went dark too! I can work the audio and air conditioning using steering wheel buttons but can't get stereo to change to another CD to play. I have to eject them all and load one at a time to listen to. Thought it was a fuse but nope. Am I doomed?
    Thanks!
  9. Martin Angelov
    Martin Angelov Junior Member
    Bulgaria
    Hello,
    i see that this thread is over 10 years old, but i fixed my display on Prius gen2 2008 with replacing of the supercapacitor NT 5.5V 473 that is connected to power management IC BD4911FM.
    Hope that helps someone.
  10. Tideland Prius
    16,680
    @Martin Angelov , please don't cross post as it looks like spam. I know you were trying to help solve other people's problems by presenting your solution but note that it can be picked up as spam by the filters.
  11. Martin Angelov
    Bulgaria
    Yeah, i'll take note.
    I posted it in few other threads with similar symptoms of "new" MFD from 2005-2009 that doesn't turn on or have blinking problem.
    Because there is only info for sending unit to someone in US to repair it or buy another MFD and this is stupid if you or someone else have knowledge to repair it .
  12. Dennis Brown
    Dennis Brown Junior Member
    33
    Baltimore County
    Three Touring
    In the special Prius Gen 2 repair manual I took an image of the methods used to enter diagnostic mode. One uses the screen touch method. This will give you error codes that might help. To Exit this mode, simply turn power off on the car.
    Since this thread appeared as current (due to above) didn't realize how old it was. However, this technique might prove useful for some here.
    #32 Dennis Brown, Jul 11, 2026
  13. Martin Angelov
    Bulgaria
    If your display is restarting or worse not starting, you can't get in service menus or diagnostic mode.
    Also it would be helpful if you provide link to this info or "image of the methods" not just that you know something.
    #33 Martin Angelov, Jul 15, 2026
