MFD Problem After New Audio Install
Discussion in 'Gen 2 Prius Audio and Electronics' started by MarsiaMS, Jul 16, 2016.
  1. MarsiaMS
    MarsiaMS New Member
    Winnipeg
    2016 Prius c
    Hello all,
    I got a new Pioneer audio for my 2009 Prius and had the electronics shop install it. While the audio is working well, the MFD touch screen stopped showing all values. I cannot see my fuel economy, battery charge, or the outside temperature.
    I took the car to Toyota dealer, and they told me that the MFD and Pioneer audio are not properly connected, and that the MFD will only work with the factory audio. Did anybody here have a similar issue? Is there an option for me that does not involve putting the old, barely working factory audio back in?
    Thanks in advance for your replies.
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    there is an adapter harness, made by scosche I believe, which the shop should have installed if they knew what they were doing. it has the 68 ohm resistor wired into it.
  4. 69shovlhed
    2,170
    752
    Delaware
    I hope the shop soldered all the connections and didn't hack up your wiring harness, or you'll have more problems later.
  5. Syndrome
    Syndrome New Member
    Netherlands
    the 68 ohm resistor will fix it, i did it today. had the same thing
  6. MarsiaMS
    MarsiaMS New Member
    Winnipeg
    2016 Prius c
    Thanks a lot for your responses. I will look into the resistor solution and write if it worked.
  7. hughdaleharris
    hughdaleharris Junior Member
    Thunder Bay
    What type of 68 ohm resistor did you use? I see options for 1/4 watt, 1/2 watt, 1 watt, 2 watt, 5 watt, and 10 watt 68 ohm resistors at my local supplier of electronic components and electrical equipment.
  8. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    All of them would work, go with the lowest cost which would likely be the 1/4 watt
  9. MarsiaMS
    MarsiaMS New Member
    Winnipeg
    2016 Prius c
    I never got to try this solution, as the car in question was totalled just a few days after. I hope I never have to deal with a similar issue on my new Prius!
  10. bisco
    52,923
    did you get another '09?
  11. MarsiaMS
    MarsiaMS New Member
    Winnipeg
    2016 Prius c
    Haha, no. I got a 2016 Prius C.
  12. bisco
    52,923
    congrats, all the best!(y)
