MFD Reboots?
Discussion in 'Gen 2 Prius Technical Discussion' started by phoenix101, Jul 6, 2009.
  1. phoenix101
    phoenix101 New Member
    South Africa
    I have a 2006 Touring and have recently noticed that if the car is in ACC mode (one push of the power button without brake), and I switch on the driving beams the MFD goes blank, the radio turns off and the MFD displays the start-up screen and then returns to normal operation. Has anyone else experienced this?
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Hi Phoenix.
    I'm not sure that I understand the order:
    1) Push (POWER) once to get into ACC mode.
    2) Switch the headlights on (?).
    3) The MFD goes blank, the radio turns off.
    4) The MFD displays the start-up screen.
    Does the radio come back on?
    Have you fully powered up the car or are you still in ACC?
    I just want to make sure I fully understand the situation before I offer up a guess.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    Sounds like it could be a bad 12 volt battery and about the right age car. Of course I'm just guessing.
  4. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I agree. From the time you push the power button (makes no difference if you go to ACC or IGN mode), up until the time the inverter comes online and begins to recharge the 12V battery, there's a heavy load on the 12V system as all the computer systems come up. With a healthy battery, I've noticed a 0.5 to 0.7 volt drop during this time. If you have a marginal or tired battery, the drop could easily exceed 1.0 to 1.5V.
  5. richard schumacher
    7,663
    1,038
    United States
  6. phoenix101
    South Africa
    Thanks for the advice guys, I will have the 12v tested and let you know.
  7. phoenix101
    South Africa
    Had it tested, and its a dead 12v battery, I'll have to replace it. thanks again.
  8. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Did the fix work?
  9. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
  10. phoenix101
    South Africa
    I have ordered the 12v battery, but there isn't any stock available in the country, I'll have to wait a while.
  11. phoenix101
    South Africa
    Installed the new battery yesterday, everything works properly again.:)
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Great news. I'm happy it was an easy fix.
    Tom
  13. bredekamp
    bredekamp Member
    569
    I'm glad it worked.:D
