MFD showing battery SOC fluctuates
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusHead05, Nov 10, 2020.
  1. PriusHead05
    PriusHead05 Member
    318
    I was driving home from work and noticed the ICE charging the battery. The SOC was at 3 bars. One second later, the battery was fully charged in the green. Why the change so quickly? Is there a lag or something?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,102
    2,005
    NJ-USA
  3. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If the vehicle only has 138k on it (verified?), and if the HV battery is original, it might benefit from balancing and or some cycling.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Your battery is 16 years old, you’ve probably got some dying cells. It’s never good when the battery starts jumping around like that
  5. PriusHead05
    PriusHead05 Member
    318
    Yes, it does have 138k on it. Does Toyota do balancing and cycling? I did just buy the car about 6 months ago.
  6. mr_guy_mann
    4,102
    2,005
    NJ-USA
    Toyota has two options . Let them replace your HV battery pack with a new one. Or buy a complete set of new battery modules from them and you install them. That's it.
    Any procedures for replacing individual modules (with used ones) and cycling - balancing is stricting aftermarket or DIY. Results will vary.
  7. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    An easiest option would be the Prolong gear from http://hybridautomotive.com/
    There are other options depending on your budget or DIY skill set.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I concur with the earlier responses. Your traction battery has lost most of its capacity. Two things conspire to cause this as they get old. One is that the cells get out of balance. So, when the module with the highest charge hits its top limit, the inverter stops charging the whole battery. When the module with the lowest charge hits its bottom limit, the inverter starts charging again.
    Another thing is that the cells themselves lose capacity amplifying the first problem.
    A Prolong grid charger can help with both of those situations. It won't make your battery new again, but it can extend the life by several years.
    Where are you in FL? If you're close enough, interested enough, and want to buy and install the cable from Prolong, you could borrow my Prolong.
    But the best fix, if you plan to keep the car for a long time, is a new battery from Toyota or, if you like DIY projects, a new kit of battery cells from @2k1Toaster. (http://newpriusbatteries.com)
    #8 jerrymildred, Nov 11, 2020
    SFO likes this.
