MFD vs. Calculated MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by PriusRos, May 13, 2007.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(kettledrum @ May 24 2007, 05:06 PM) [snapback]449346[/snapback]</div>
    Absolutely not. I always fill until it stops. Then remove and reinsert the nozzle and do one more click.
  2. jiw395
    jiw395 New Member
    119
    NORTH WEST INDIANA
    My 2006 prius 'MFD' was right on the money in the beginning, with-in a few tenths. Now, the 'MFD' shows in the low 50's mpg, but when I calculate the numbers, its always in 42/44 mpg range, ALWAYS LATLEY,and I haven't changed my filling up tactics ,when it shuts off, I stop, and most of the time{like 90%} I use the same pump at the same station {Costco} . Its really disappointing, but the numbers don't lie....
  3. jiw395
    jiw395 New Member
    119
    NORTH WEST INDIANA
  4. jiw395
    jiw395 New Member
    119
    NORTH WEST INDIANA
    confused again, this time it was dead nuts,the MFD was the same ,50.3 both ways,,,,,,,,,,til next time. one thing, I usually fill up no less than a 1/2 tank, however for some reason I got brave and went all the way down to 1 pip, not sure why I waited so long but i did, maybe that has something to do with the differences I 've been seeing/having...
  5. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(Norman H. Renehan @ Jun 9 2007, 01:06 AM) [snapback]458525[/snapback]</div>
    Not sure I understand -- are you saying the MFD and the calculated mpg were both 50.3?
  6. PearlDriver
    PearlDriver Junior Member
    76
    Snohomish, WA
    In ten months 19196 miles my difference between actual and theoretical is about 3%.
    11.9/379. With the theoretical milage slighly higher. My tank differences range from -.95 to +1.25. Which is about a 10% swing.
    If my MFD versus actual was much different than what others here are reporting I would:
    First be certain of my math
    Second, go to my Toyota dealer.
    Each tank may vary up to 15% but the long term (six tank minimum) should be under 5%.
