Mg1/mg2 renamed?
Discussion in 'Gen 3 Prius Technical Discussion' started by Yippeekyaa, Aug 21, 2017.
  1. kalamazandy
    kalamazandy New Member
    Kalamazoo, MI
    I was able to get it working with ODB Fusion on my 2011. I used the 2012 PID and it worked fine. It was a little sketchy though.
    If you do run that, you choose the custom PID, and just run "Test" on both of them.
    Lo an behold, I now have only one beep when I initially go into reverse, then the rest of my reversing ride is nice and quiet.
  2. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    I have the obd fusion but don’t have the PIDs you list, is there an additional files that needs to be dloaded as an add-on to fusion?
    2010 Gen 3
  3. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    Both MG1 and MG2 can act as a motor or a generator depending upon the driving scenario.
    Also they both can rotate in either direction.
    kevin
  4. kalamazandy
    Kalamazoo, MI
    Prius Gen3 - Deactivate Reverse Beeping | PriusChat
    Download that csv. In order to get it In the iOS app you have to hook your phone up to a computer with iTunes (Apple sucks). Then find the app on the phone within there. THEN you can add the file through that file menu. If you're on a mac it Might be easier. On PC you can't drag and drop it. You actually have to add the file through itunes like that.
    Once there, in the file under "custom PID" you can choose the two custom ones and simply "test" them since they are a run once to change it option. You can edit the csv in Excel, or google spreadsheets, to change it back if you want that. The way it's set up doesn't disable the backup beep completely. It beeps Once, when you hit reverse and that's it.
    Jayw13702 likes this.
