Mg1 motor temperature number one overheating 360° f
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Travis Sanders, Dec 25, 2021.
  1. Travis Sanders
    Travis Sanders Junior Member
    63
    25
    Hawaii
    So my friend brought me his 2010 Prius with 100,000 miles on a tow truck because it broke down. I found corrosion on a pretty important fuse and soldered wires into the fuse box with an external inline fuse. Then the p lock error on the display went away and I was able to drive the car although it seemed to surge a little. I stop the car and held the break while pushing the gas all the way down in order to charge the traction battery. The engine revs up maybe a little higher than it's supposed to and then suddenly drops to idle and repeats. I held it like this for a while and then noticed motor temperature number one over 360° f. I hate to believe that's a real temperature but letting it rest did bring it down to normal temperature like motor number 2. After letting it rest I put it back in drive and slam the gas and brake all the way down. Watching the amperage charge the battery motor temperature started rising rapidly.
    So what do you think? Are it's windings shorted out? Is there any better way to tell what's going on by looking at the live data other than just watching the temperature climb? Has anyone on here had an electric motor go bad and can you tell me what your symptoms were?
  2. Travis Sanders
    63
    25
    Hawaii
    It's strange though that it also says motor number two had a super high temperature before. I'm not sure when it recorded this number.
  3. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    I think the inverter coolant also cools the transmission in this generation of Prius. Check the inverter reservoir to make sure it has the proper amount of radiator fluid, and look to see if it's circulating. Cooking the motor is really bad for it. If windings are shorted then that will also generate heat.
    #3 ammdb, Dec 25, 2021
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,108
    Tampa, FL
    No. But if it stays overheated for very long, they will be. If the windings were shorted, it would throw a code and you'd get the dreaded red triangle. A general rule of thumb with electric motors is that every ten degrees above the max temperature you run it cuts its life in half. As mentioned, check the inverter coolant first. Also check the transaxle fluid. If the inverter coolant is OK, I'd drain, examine (send for testing?) and replace the transaxle fluid. MG1 is smaller than MG 2, so it will change temperature more quickly. Plus it's the one that charges the battery, so it working harder in your situation.
    I think I've only ever done this a couple times but I seem to remember the same behavior. That was in a Gen 2. Others more experienced can correct me if I'm wrong.
  5. Travis Sanders
    63
    25
    Hawaii
    I can see it's circulating and when I put my hand on the pump I can definitely feel it's buzzing along. The inverter temperatures are fine.
  6. Travis Sanders
    63
    25
    Hawaii
    I have five Priuses all generation 2. None of their engines rev up and down during the power braking charge routine.
  7. jerrymildred
    11,508
    14,108
    Tampa, FL
    Then I think I'd either be checking the transaxle fluid or just take it to a Toyota dealer or a hybrid specialist.
  8. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    How do we know if 360 degrees is outside it's normal operating range. I would think the hybrid system would set a trouble code if something is overheating. My 24 watt soldering iron tip is about 650 degrees. Might depend on what part of the motor the temperature is taken.
    #8 ammdb, Dec 26, 2021
  9. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    I have a 2010 Prius, 104,000 miles. When I do the battery life expectancy test with Dr Prius, the test requires charging the battery by flooring the engine. I experience what you are talking about except that the engine stops completely and Dr Prius says to take my foot off the pedal, then floor again. It takes 4 or five cycles to charge the battery.
    I've wondered whether this is normal or a sign of a problem but there are no codes or other issues. My Prius runs perfectly in regular use.
    jerrymildred likes this.
  10. Elektroingenieur
    2,515
    3,257
    Three Touring
    In general, it‘s better to rely on the power management control ECU’s self-monitoring and self-diagnostic programming, rather than on ad hoc tests such as this, for which Toyota simply hasn’t disclosed the thresholds and other information needed to make a reliable judgment about whether a failure exists.
    If the car wasn’t used for a while, so the HV battery might have a low state of charge, just leave the car in READY, with the parking brake set and the transaxle in P⃣, for 30 minutes, so the engine can run as needed to recharge the battery. For new vehicles in inventory, Toyota tells dealers to do this at least once every 60 days.
    I’d expect a “Generator Temperature Sensor” diagnostic trouble code (DTC), such as P0A37-260, P0A3A-258, or P0A39-259, to be stored, if the MG1 temperature were outside the expected range for long enough to matter. Similarly, if there were a shorted winding in MG1, I’d expect a “Generator Inverter Performance” (P0A78) or “Hybrid Generator Performance” (P0A92) series DTC to be stored.
    If you’re referring to the “Mtr-Temp (MG2) Max” value in the Data List, the Repair Manual (more info) for 2010 doesn’t mention a time period, but in the 2013 and later editions, Toyota adds the words “after power switch turned on (IG) in current trip.” I imagine this applies to all third-generation models.
    Travis Sanders and jerrymildred like this.
  11. Travis Sanders
    63
    25
    Hawaii
    I finally had some time to address this problem again today. I haven't been driving it. I drained the fluid and it looks pretty trashed compared to my other two Priuses that I drained which even had more miles than this one.
  12. Travis Sanders
    63
    25
    Hawaii
    I drained out three quarts of that nasty fluid. And fit 3.5qt back in. So it was 1/2 quart low.
    #12 Travis Sanders, Jan 8, 2022
  13. Travis Sanders
    63
    25
    Hawaii
    Noticed Front passengers wheel speed sensor wiring harness completely destroyed. I have to look up the diagram and see what color wires go where if polarity matters anyway.
  14. jerrymildred
    11,508
    14,108
    Tampa, FL
    I think you're right. Someone put in the wrong fluid. And with the glitter coming out, putting in the right stuff probably won't fix it now. :(
    Travis Sanders likes this.
  15. meeder
    meeder Active Member
    239
    161
    Doesburg, The Netherlands
    You could try filling it with the correct Toyota WS fluid and replacing it again after a short while.
    If it's already damaged beyond repair it won't harm anything more.
  16. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I've never seen MG1 and MG2 temps vary more then 30 degrees. With all the other system temps reading "normal" with one outlier I'd be looking at the sensor providing bad data which is causing a cascade of problems. Sensor or wiring issue that is messing with the signal is where I'd start.
  17. jerrymildred
    11,508
    14,108
    Tampa, FL
    So, what came out of the transaxle was anything but Toyota ATF WS, plus it was full of metal flakes. That fruit is so low hanging that you have to bend down and pick it from the ground. I'm with @meeder; get the low hanging (aka easy) fruit first. Put in the Toyota ATF WS, run it a few miles, and see if the problem persists. There's a good chance that it will because metal flakes are not supposed to come out in the transmission fluid. If the problem goes away, drain and fill again and pray that the thing will hold up for a while.
    ASRDogman and Travis Sanders like this.
  18. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    It still looked ATFish. It's not what we typically see coming out of a Prius either color wise or "glittery". People seem to forget that there are still an awful lot of gears in that transmission moving around that can make metal like that. Granted, none of that is good.
    I'd be shocked if a splash lube style lubricant caused temp spikes like that. It doesn't transmit any power in the Prius so blaming improper fluid on that doesn't make a lot of sense. The only way it could possibly contribute is if the chemistry started "eating" materials inside there.
  19. jerrymildred
    11,508
    14,108
    Tampa, FL
    Yup! That's what I'd suspect given the symptoms.
  20. Travis Sanders
    63
    25
    Hawaii
    I've been working on cars 25 years. I've never smelled transmission fluid so strange. This explains the weird hot smell that I get opening the hood. I worry the wrong fluid deteriorated the coating on the motor windings and the motor is shorting out. Though I'm not getting other trouble codes related to shorted windings. I've got to reinstall techstream on the virtual machine or else I'd already have an answer about whether or not it's still running hot.
