MG2 Temperatures
Discussion in 'Gen 3 Prius Technical Discussion' started by Gliderguy, Nov 5, 2019.
  1. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    I recently got Torque pro and OBDlink LX bluetooth adapter. I have been studying several things about my 2012 Prius, but I have noticed that the MG2 temperature really goes up after a long climb (I drive from Phoenix up the hill to Prescott regularly, 6 or 7 miles of continuous 6% grade at an average real speed of 70 mph) I have noticed at the top of the climb the MG2 may be around 230 F. This is with moderate temperatures of around 70 to 80 degrees ambient. I am wondering if some part of the cooling system is not working correctly, or is that amount of temperature creep under a substantial load normal? It does drop maybe 20 degrees back into the low 200s before I get home, once I am out of the sustained climb. The MG1 temperature is a steady 30 degrees cooler, and even at peak-worst case, both inverter temperatures stay below 140. Anyone else have any experience in this matter?
  2. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    I monitor mg1 & mg2 religiously since the beginning of summer. My commute is mostly flat, mg1 & 2 are fairly close -/+ 5f from each other. Usual summer for my commute hour drive, 190F. With highs in the 70s now, mg1 and 2 are in the 150s
    Highest was 210F driving from Sacramento to SF that’s about 2.5 hrs of driving during summer will hills going 65mph.
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    In your shoes, I would drive 55mph uphill if behind traffic permits
