Mice in my car
Discussion in 'Gen 2 Prius Main Forum' started by gavilan, May 18, 2007.
  1. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    I have a mouse behind the driver seat, in a briefcase, with a cool little red light.
  2. clintbhs02
    clintbhs02 New Member
    32
    Mice only go where there is food, and they will chew thru anything to get it.
    Get some Decon mice/rat killer and place it in ur garage.. they will smell it and go for it.. and a few days dead. Leave it in there. Its not a Toyota problem, you just have a mouse problem in your house.
  3. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(bulek @ May 18 2007, 04:56 AM) [snapback]444751[/snapback]</div>
    Not if the kitty has a cat box in the car, and you clean it regularly. But the best would be to clean out the garage so you can park inside, then keep several cats in the garage.
  4. Old Marine
    Old Marine Junior Member
    Milton, Florida
  5. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    <div class='quotetop'>QUOTE(dulcimer @ May 20 2007, 09:18 AM) [snapback]446140[/snapback]</div>
    We have 6 cats, 3 mostly outside. The Prius is OK so far, but I found critter tracks, and chewed insulation underhood on my Subaru, which also sits outside. So far it was only insulation, which I taped over. You would think wiring manufacturers could put some foul tasting stuff in the wires to discourage this activity. The cats don't seem to discourage the little critters.
  6. snick
    snick Junior Member
    29
    Riverside, CA
    <div class='quotetop'>QUOTE(stargazer0725 @ May 18 2007, 01:16 PM) [snapback]445160[/snapback]</div>
    I live out in the country, with rabbits, mice, rats, kangaroo rats, owls, hawks, coyotes and bobcats. I think if I put them all under the hood there wouldn't be any problem :) but I had two instances of my Chevy Astro, a Volvo, and a Chevy Cavalier being chewed up (wiring and hoses), before I found a solution. I gotta tell you, I was amazed that a mouse could chew completely through a battery cable! So anyway, after replacing several wiring harnesses, dangling poison bait under the hood, traps, a $40 ultrasonic pest repeller, and cussing, I found a solution.
    Park with your hood up. No kidding, it actually works.
    I was getting ready to put Irish Spring soap bars under the hood, which I also heard works. I found a huge stick nest in my motorhome engine area, but no wiring damage there, thank heavens. Count on $400 to $1000 when you have a dealer fix mouse damage.
  7. Trath Mutters
    Trath Mutters Junior Member
    Farrell, Pa.
    I've asked my dealer to stock snakes of various colors.
  8. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    124
    36
    Wisconsin
    Try dryer sheets. The smell is supposed to repel mice.
