Michelin Defender tires report
Discussion in 'Gen 3 Prius Fuel Economy' started by GardenWeasel, Apr 9, 2017.
  1. ChapmanF
    19,060
    farmecologist likes this.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    RMB and farmecologist like this.
  3. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    I loved my defenders - I got about 67,000 miles out of them before chickening out and replacing them. I took about a 2-4 MPG hit for the first 10K miles, then they seemed to catch up. Wet handling was incredible compared to my OEM Bridgestone Ecopias.
    I've got Yokohama Avid Ascends now, they're working out well. And everyone on my block with a compact import has replaced their tires with Avid Ascends.
    One side-effect of hanging out on priuschat.com is that you obsessively check out sidewalls to see what people have bought. Or is that just me?
    Threej and farmecologist like this.
  4. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    Would you know how much tread was left at 67,000 miles...when replaced?
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Don't hide the MPGs you were getting with those tires, post it :LOL:
  6. ChapmanF
    19,060
    Saaay ... there's that Vredestein Quatrac 5 again. I wonder what people are thinking of those now that they've been around a bit longer.
    I thought they were a little too new to gamble on last year, and bought General RT43s instead.
  7. Mendel Leisk
    42,380
    I'm glad I'm not the only one, lol. Have you noticed with Michelins: the brand is really easy to spot, but the specific tire name is always very low-key; you have to stop, crouch down, look close. Which is a little embarrassing...
    GardenWeasel and RMB like this.
  8. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Good stuff. Thx for the info! I'm going to try them on our Elantra GT ( already have Defenders on both Prii ). The Avid Ascends seem to have a cheaper entry point than the Defenders as well. However, I never seem to see them on sale. have you?
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Note this from the 2018 Prime owner manual - if you change the tires, certain death may result (clearly written by the lawyers). :eek:
    Make sure that all tires are of the specified size, brand, tread pattern and total load capacity. In addition, make sure that the tires are inflated to the recommended tire inflation pressure level.
    The ABS, TRAC and VSC systems will not function correctly if different tires are installed on the vehicle.
    Contact your Toyota dealer for further information when replacing tires or wheels.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I wonder if it’s 2am and AAA puts in a new tire on your prime because let’s just say a razor blade is stuck on the blown tire, we’d have to call Toyota first?
  11. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    If you have a Costco membership and you get the Michelins when they have $70 off the set, plus free installation, you may well end up paying less than for the Avid Ascends.
  12. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    35,000 miles on my Defenders, and an update to report. Today we went across town for birdseed and other assorted items and when back in the garage I was shocked at my FE as below. No special effort was made, but I am not an aggressive driver.
  13. Mendel Leisk
    42,380
    Are they plain Defender, or Defender T+H? I'm just wondering if they've messed with the rolling resistance, with the new iteration.
    GardenWeasel likes this.
  14. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    The plain Defenders.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I went with new Defender T+H treadwear 820 last month, and decided to not go w/Defender Green X 480 treadwear. T+H has harder rubber wear obviously and weighs in at 18lbs new. No regrets....yet :LOL:
    Mendel Leisk and GardenWeasel like this.
  16. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    7BDF8D62-E9A2-4F36-B7C2-9A61435FA2E1.jpeg Mine say Green X with a treadwear of 820.
    Grit and Mendel Leisk like this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If you can find another set of Green X treadwear 820, keep it stashed. I know those have been discontinued, looked everywhere for old new stocks w/no luck. My previous was also Green-X 820, yielded 63-64 mpgs daily for the last 12 months with them. A good thing came to an end last month when they had 1 mm left til wear bar touches the road.
    #57 Grit, Jan 1, 2020
    RMB and GardenWeasel like this.
  18. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    Thanks for the info! I just know I’ve never had tires that were so easy to get great FE. And they hardly show wear!
    ALS likes this.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    After 5,000 miles, the T+H tires finally broke in. Getting mid 60 mpgs on the commutes again, back to 63 mpg per tank also. So yes T+H 820s are equivalent replacement to the discontinuednDefender Green X 820s (y)
  20. Mendel Leisk
    42,380
    The king is dead, long live the king?
    I was thinking it was the same tire, they just changed the warranty, name, rolling resistance logo. Be nice if they'd be candid though.
