Michelin Energy Saver A/S
Discussion in 'Gen 4 Prius Fuel Economy' started by GaryD1, Dec 2, 2018.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Read Lee Jay's comment. He claims 20-30% hit continued and never recovered.
    52,863
    mine were the same or a little better, from the get go
    Data Daedalus likes this.
  3. Mendel Leisk
    42,354
    I've also had some new tires where mpg didn't skip a beat.
    bisco, GaryD1 and Raytheeagle like this.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I'm going with Ecopias when it comes time for new rubber. I've had great experiences with them on my 2004 Prius. When the weather turned cold about a month ago, I instantly lost 5mpg. I would say that some loss is due to the cold weather, some due the newer tires and some due to the fact that you are riding on different tires from oem. Have you checked your tires pressures after getting the tires installed?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    When I put Bridgestone turanza Serenities on our 2010 at 120 k miles, I was averaging 48 mpg displayed. With the previous Coopers I was at 47 and they only lasted 65 k miles.
    The original Ecopias lasted 55 k miles and delivered 50 mpg.
    Now with 192 k miles on the Prius we’re at 49.4 mpg displayed.
    So not much difference here between different brands.
    I buy based on tread life and will be looking for another round of Serenities when these give up the ghost.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Yeah...new tires have more rolling resistance than old ones, but this is worse. I'm wondering if it'll improve after break-in. I've only got a few hundred miles on them.
  7. Mendel Leisk
    42,354
    What's weird: they're supposed to be LLR leaders. :confused:
  8. bisco
    52,863
    low leaking resistance?
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
  10. bisco
    52,863
    i must have lucked out and got the 'other' energy savers:rolleyes:
    Data Daedalus, Raytheeagle and padroo like this.
  11. Mendel Leisk
    42,354
    Oh eff, my turn!
    Data Daedalus and padroo like this.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    I never plan on wearing my TOYO's out.
  13. Salamander_King
    11,024
    8,980
    New England
    Of course, on PRIME it is difficult to compare mpg from different set of tires. And EV range can vary day to day even with a same set of tires. I don't know what is the good way to compare one set of tire and another set on PRIME for fuel efficiency except running full tank of gas without any charging, which is what I am doing on my new set of Michelin Xice winter tires.
    #33 Salamander_King, Dec 2, 2018
  14. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    This is my 3rd set of Michelin Energy Saver A/S. I have 800 miles on new tires. I always got good gas mileage with new tires without breaking in period with the exception of this set.
  15. GaryD1
    302
    138
    Seagrove, NC
    This is the same tread I have
  16. bisco
    52,863
    i know, go figure. i think mine have the 44 psi max, they are about 1 1/2 years old, iirc
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    But you're not running either 51 or 44 - that's only the tyre's maximum safe pressure, irrelevant - your pressure is on the tyre pressure placard inside the door.
  18. alanclarkeau
    7,045
    7,593
    They need running in - 1000 kms. Is this just one tank-ful - use a couple of tanks, not just the first one, as you can get a false reading with any tank refill. Do you normally log your fills?
    Not sure about your temperature there - if it's cooling down, and particularly if you've got a Li-ION battery, that will affect economy.
    What are they like to drive on - better grip?
  19. mikes951
    mikes951 Junior Member
    46
    US
    Gas mileage always drop when temperatures drop can lose 10mpg.
  20. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    He mentioned he got a new alignment also. I'd also look into that. Perhaps they made a mistake. That would certainly effect mileage also.
    Robert Holt and GaryD1 like this.
