Michelin Energy Saver - Discontinued?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eseerc, May 13, 2019.
  1. eseerc
    eseerc Junior Member
    53
    Central PA
    HI everyone,
    I am in the market for a new set of tires for my 2010 Prius and settled on the Michelin Energy Savers. This morning I called my local Toyota dealership to order and was surprised when they said the tire was not available. Their words were "maybe it is being discontinued". I then tried my local Sam's club and was told the same thing, the tires are not available for order and may be discontinued.
    Has anyone heard of such a thing? I know the tires are available on TireRack, but am surprised two local places are mentioning the possibility that they are discontinued. If this is the case, I'm not reading much good about the Michelin Premiers so may fall back onto the Bridgestone Ecopia 422s.
  2. Mendel Leisk
    42,253
    Are you talking about Energy Savers or Energy Savers A/S? The latter is the All-Seaon version, typically more widely available. The former is Summer-Only, not that common?
  3. eseerc
    53
    Central PA
    Sorry I should have specified, the Energy Saver A/S
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    The michelin defender is a great alternative, longer lasting and less expensive which makes up for possibly slightly lower mpg. It is sold as the X tour at Costco and Sams for about $10 less per tire than the defender branded tire.
  5. Mendel Leisk
    42,253
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Like energy saver a s green x? They have an updated version of that one which performs worse. Mine are date 2012 the wear tread and temp rating specs are better than the new version. You figured new version would perform better and spec wise also. But profit margin is most important to them.
  7. Mendel Leisk
    42,253
    Maybe amend the title while the edit window is still open. There's button somewhere around the first posting, allows you to do this.
    You might be onto something. I've been rolling on new Primacy MXM4, also Green-X, just one tankful now, and they seem pretty sticky: seems like there's that constant need to push the gas just a little harder. Subjective, but there. And it's reflected in our fuel consumption, the last tank: took a bit of a dive...
    This is comparing to 9 year old, hardened up Pilot HX MXM4 (also Green-X label on sidewall), so somewhat apples/oranges, but you have to wonder. I'll live with it, and hoping in a few 1000 kms they'll improve.
    #7 Mendel Leisk, May 13, 2019
    Merkey likes this.
  8. bisco
    52,767
    try tire rack, that's where i got mine. they are always in short supply for some reason.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    They maybe telling you a truth. If you go to Michelin US site, Energy Saver A/S is still listed, but you can't order them on-line, unlike other tires like Energy Saver (summer tire) on the photo below. That seems to indicate at the least they are currently out of stock for new orders.
    Truck Tires, Car Tires and more – Michelin Tires
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If you place an order for them, they call ya to let you know those are being replaced with an equivalent newer model; T S ones. Happened to me, I’m rolling on 3/32” now :sick:
    Merkey likes this.
  11. Salamander_King
    11,024
    8,977
    New England
    Well, my OEM tires are down to 5/32, and won't be too long before needing replacements. That's one less tire I have to consider for my next set. On one hand I want the best tires money can buy (usually expensive) but on the other hand I also want to try really cheap ones to see the difference.
  12. bisco
    52,767
    tire rack shows them in stock
  13. Salamander_King
    11,024
    8,977
    New England
    If they are discontinuing it, what's in stock now may be the last chance to grab some. I wanted to try them on my PRIME, but I don't think they will be available next summer when I need to buy a set.
    CR94 likes this.
  14. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
  15. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    Merkey likes this.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    It does show in stock, but it's the treadwear 820 that I'm after. The green x on there has 480 rating.
  17. pghsebring
    pghsebring Junior Member
    Miami
    I went through this like 3-6 months ago I think...I knew I should have grabbed them when I had the chance. I used to have the good ones (820 treadwear) on the old prius we sold and I was looking for new tires a few months ago for the current prius and realized the new version is garbage, so I went and found the tire ID for the old ones in our size and there were like 2 places out there that had a pair each, I would have had to buy a set from each place, it just seemed like too much work and I stalled...now they're gone and garbage is all that is left. Sucks. Anyways I broke down yesterday and ordered Continental TrueContact Tour, 91H speed rating, they are 800AA, we will see how this goes, I couldn't wait any longer. I hate when companies cancel good products!
    Merkey likes this.
  18. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    Merkey likes this.
  19. Joshman
    Joshman Junior Member
    Kansas City
    This is a HUGE BUMMER. I just went through this experience as well. Energy Saver A/S shows up on Costco website, but says "temporarily out of stock". Costco rep says it's likely discontinued as they can't even order any. These tires were incredible for the price and I was ready to put on another set without question. Great MPG, quiet, lasted me almost 80,000 miles (almost all highway as courier service).
    I went with Michelin Premier A/S. Great tire, but I'm seeing the MPG hit right away. Maybe worth it if they have additional wet grip, but I never had any issues with the Energy Saver A/S. I was tempted to get the X Tour (defender), but the 820 tread wear just turned me off. I have the X-tours on the highlander, and they are a bit noisy. Different car, I know, but I wasn't willing to risk it.
  20. royrose
    1,389
    953
    Foot of Pikes Peak
    What is wrong with the tread wear rating of 820?
    Salamander_King likes this.
