Michelin HydroEdge experiences?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 1rocketman, Sep 14, 2008.
  1. 1rocketman
    1rocketman Junior Member
    25
    Rockledge, Florida
    Does anyone have any experience with these on a Prius? My 2004 needs tires, and it currently has 185/65 R15 Goodyear Integritys. From what I've been reading, the HydroEdges seem like they might be a good choice.
    My general criteria are wet weather safety/handling/etc since I live in Florida, maintaining 50+ avg mpg, and long lasting treadwear.
    Thanks in advance for any thoughts.
  2. donee
    donee New Member
    2,956
    195
    Chicagoland
    Hi 1rocket..,
    I changed out the Integrities at 5000 miles on my car to Hydroedges. Discount Tire had a sale, and also gave a reasonable credit for the Integrities. I also had a scary slide in traffic which convinced me. It was one of those days , the first rain in a couple weeks, when the roads are greasy.
    I like them. They do make noise at low speed - kinda like a womp-womp-womp. This is from the factory siping which improves wet weather stoping. The mileage is a little worse. Some people say 2 to 4 mpg worse. Although, I am in the mid 60's mpg right now. The mileage will be quite a bit worse for the first 1000 miles, however. Just like it was with the Integrities.
    The tires have silica in the coumpound, which helps with wet weather stoping, reduces heating of the tread (which helps gas mileage), and improves tread wear. Most LRR tires have high silica content.
    My tires are wearing mostly flat, but I am running at 42/40 psi.
    I had these tires on my SL2 before the Prius, and the change was dramatic vesus the stock Firestone tires. Stopping distance on a damp road was down by 1 to 2 car lengths from 40 mph. Freeway handling was dramatically better.
  3. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I got my hydroedges about a year ago. Actually I got a wider size, which I do not recommend. Yes, any tire will lower your mileage during the break in period as the newness is worn off the tire. My mileage dropped 6-10 mpg. BUT, that's back up now. After conferring with others on this site who had these tires, we pumped them up to 50-48 and the mileage jumped right back up.
    I you purchase the OEM size, your mileage drop should not be significant, but at least during the breakin period, you may want to pump them up to maybe 44-42 or so.
    I like my tires and after a year, having now driven them in all seasons of the year here in the mountains, i'd buy them again, but i wouldn't get the 205 width, I'd stay with tjhe 185 size.
    Good luck!!
  4. VaPrius
    VaPrius New Member
    150
    Virginia Beach
    I have them on my '05. Great wet weather handle, no snow yet though. Great handling all around. I've not noticed any extra noise or MPG hit.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    185
    49
    Chesterfield, VA
    This will pretty much echo the others. Pros: better handling than Integritys (wet and dry pavement), much better tread life (about 19K miles now and little wear). Cons: an estimated 5-10% fuel economy hit at first (much of which has been regained), somewhat noisier.
  6. john1701a
    john1701a Prius Guru
    12,422
    5,044
    57
    They're great! My first set, which didn't have as good of a tread rating as the newer ones, lasted 4 winters. Getting a second set was a no-brainer. I definitely recommend them.
  7. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    Another thumbs up for the Michelin HydroEdges. I've had them on my 2004 for 50k miles, running at 42/40 psi. Now, they are wearing at the edges, but center is still good. Rotating them every 6,000 miles - they are unidirectional. Much better all around than the Integrities -- with big improvement in the rain & snow. But noiser. Tirerack members like them, and so does Consumer Reports.
    If I don't go try Goodyear TripleTreds next time, I would repurchase the HydroEdges.
  8. 1rocketman
    25
    Rockledge, Florida
    Thanks for the excellent replies and information!
    If you don't mind a followup question in the same thread, what do you think about
    going to a 195/60/15 sized tire?
    Would this affect my handling or mpg?
    Thanks in advance.
  9. Boo
    Boo Boola Boola Member
    5,051
    477
    97
    Flushing, NY
    I like the 195/60/15 size, as opposed to the OEM 185/65/15.
    It promises better and safer handling and braking distances, but probably around 2 fewer mpg.
    Considering the poor handling and braking distances of the Standard Prius, that's a trade I'd be willing to make any day of the week.
  10. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I think it will improve your stopping distances the most, and also improve some cornering and handling, but should cost some fuel economy.
    In a previous car I went from the stock width of 195 to a 205 width and at most lost 1 - 2 MPG, but that car only got 32 MPG (so that might have been about a 5 % loss)
    Check with your tire dealer because many have started to adopt a new policy that they wont put a tire that is of a non OEM size on your car.
  11. hobbit
    hobbit Senior Member
    4,089
    463
    Bahstahn
    My hydroedges are approaching 50K old by now; still going along
    fine although they've gotten a bit noisy because I had a slight
    misalignment of the right-rear wheel that caused minor feathering,
    and then I swapped that tire to the front [different camber] and
    it was a lot noisier. [Said misalignment has since been fixed, as
    far as I can tell.] But none of this affects tracking/turning/grip,
    and at this point I'm actually relieved to see some other reports
    of noisier operation because I thought it was just me. I'll
    run 'em till they die, which will probably be well over another
    50K on them so it'll take a while. Not sure if I'll go with another
    set of HEs then or try moving to one of the Energy MX-series.
    I run mid-fifties pressure, doing mid-sixties MPG tank to tank
    in typical local mixed driving, and the wear is dead-even [other
    than the slightly feathered bits]. I've crawled my way out of
    some fairly hairy snow situations with them, too.
    And I think the V-tread just looks kinda cool.
    _H*
  12. Ari
    Ari New Member
    165
    My experience after ~5k miles:
    Pros:
    - They look great
    - Grip is excellent
    - Supposedly they will last a long time
    Cons:
    - They are noisy
    - They are noisy
    - I probably lost ~2mpg because I went with the 195 size
    Next time I would opt for the X Radial from Costco.
  13. PA Prius
    PA Prius Active Member
    734
    226
    SE Pennsylvania
    Hobbit, your info was helpful. I've been running my Integrities at 50/48 and they are about at their end. The outside edge is worn the most. Center and inside a bit less.
    I'm wondering if others who are running the HydroEdges at 50+ psi have the same experience as Hobbit's even wear. I'm guessing I'll take a slight hit in mpg running the HydroEdges at the same psi as my Integrities, right?
    PA P
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,523
    Southwest Colorado
    Mid-fifties psi, Hobbit ? I'm under the impression the sidewall max is 42 or 44 psi.
    I bought these tyres less than a month ago. so no winter experience or exciting driving to report yet. Set at 42 front and 40 psi rear they are quiet, and after 1000 miles mpg is about 97% of what I expect on the highway.
  15. JimboK
    2,817
    185
    49
    Chesterfield, VA
    I too run 50+ with even wear after about 20K miles. Tread depth measurement about 3K miles ago verified even wear. Visual assessment since then suggests the pattern (or lack thereof) continues.
    Your statement about the fuel economy hit is correct.
  16. PA Prius
    734
    226
    SE Pennsylvania
    Thanks JimboK and SageBrush. I really wish I could find a tire that would improve rather than decrease my mileage, but I guess you just can't beat a set of bald Integrities!
    PA P
  17. SageBrush
    11,627
    2,523
    Southwest Colorado
    So true, PA Prius ! :)
  18. miscrms
    miscrms Plug Envious Member
    2,076
    521
    Phoenix, AZ
    I think I'm sold on trying a set of Nokian i3s. Several folks have actually reported mpg improvements over the Integrities, as well as much better handling, traction, and wear. Before that I was seriously considering buying a set of "pre-broken in" (used) Integrities off ebay :) Only bummer is I'll either have to have them shipped from MN, or drive to Colorado to get them. Not a lot of call for Nokians in Phoenix apparently :rolleyes:
    Rob
  19. PA Prius
    734
    226
    SE Pennsylvania
    Actually my current Integrities I got off this site-- next to new, $80. for four, including shipping from CA to PA. Sure I'd do it again! Yes, the Nokian's have sounded attractive to me too.
    PA P
  20. dbarry
    dbarry Member
    114
    Houston Texas
    I've got 30K on my hydroedges, and totally HATE them.
    As many have commented, they are VERY NOISY. In fact, it appears the more miles you put on, the noisier they get. With every tire rotation you go through a 3K mile period of LOUD tires - even though my Prius dealer has checked my alignment every 10K. It's embarrassing how noisy.
    IMHO, for $125/each tires it's nothing less than a ripoff. I've written Michelin about them, and gotten no response.
    I had MXV-4's on my Prius before (put them on right after I got the car), and they only lasted 30K before getting really slippery in the rain.
    I will probably toss the Hydroedges in the spring and get something more reasonable - aka NOT MICHELIN.
Loading...
