Michelin or Toyo?
Discussion in 'Gen 5 Prius Main Forum' started by NonFormulaic, Aug 31, 2023.
  1. NonFormulaic
    NonFormulaic Member
    62
    45
    San Diego
    The 19” tires are either Michelin or Toyo. What might be the percentage breakdown of each brand coming in as original equipment? Is one brand preferred…and why? I looked both brands up on Tire Rack for Prius Limited…if you were to order them, there’s a huge price difference. Clearly, the Toyo brand is the better deal. This might be especially true as there’s zero availability on the Michelin.
  2. BacknBlack
    BacknBlack Junior Member
    24
    22
    2023 Prius
    Thanks for posting this!
    I'm curious as to the breakdown and also if there's any correlation on which cars (or trim levels, primes, etc.) receive which tires?
    Do all Prime's come with Michelin tires? Or Limited trims? Or is it simply random due to availability on any given day on the assembly line?
    I have a XLE with Michelin's. Build date 6/23
  3. Gokhan
    Gokhan Senior Member
    6,692
    2,651
    Paramount CA
    That's the first time I've seen Michelin on a Prius as OE. Michelin is typically the highest-rated tire in the world.
    I really like the OE Dunlop on mine—handles like a charm and excellent fuel economy. I didn't like the OE Toyo on my previous one. Nevertheless, all will work.
  4. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    I got Michelins on my Limited (black); build date July? (picked up July 18th)
  5. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Mine came with the Toyos. Not a fan. When I switch over to 17 inch this winter, going with Michelin X-Ice and then probably Michelin Defender 2.
  6. CeruleanBlue
    CeruleanBlue Member
    67
    28
    NC Triangle
    2023 Prius
    Michelin on my Limited.
  7. Jim Call
    Jim Call Active Member
    107
    115
    Asheville
    2023 Prius
    My XLE (picked up April 18th) came with Toyos. Not bad but noisy on rough surfaces. Seem to handle well. My local dealers can get either Toyo or Michelin same day if needed. I'll be getting Michelins next even though $100/tire more. I've heard a few say not to expect more than about 25K-30K miles from the Toyos. We'll see....
  8. BacknBlack
    24
    22
    2023 Prius
    The build date (month/year) is on the upper right corner of the black tag/bar code in the driver door jam...
  9. NonFormulaic
    NonFormulaic Member
    62
    45
    San Diego
    Prius Limited…just had it delivered. Michelin 19”. July build.
    Surprisingly smooth and very quiet. Icy cold A/C here in So. Ca Desert (110 degrees).
    I was within an inch of the Prime SE…Went with non Prime as I didn’t want to be in the mix of owners waiting for a possible fix of the well documented charge issue. Supposedly heat sensitive…which would make my car high up on the list. IMG_2266.jpeg
    #9 NonFormulaic, Sep 2, 2023
    BacknBlack likes this.
