For Sale Michelin Primacy MXM4 215/45/17 tires
Discussion in 'Private Sales' started by Thanh Tran, Apr 3, 2015.
  1. Thanh Tran
    Thanh Tran Member
    104
    77
    Anaheim, CA
    SOLD!
  2. Cezarcaz
    Cezarcaz Member
    102
    49
    Chino
  3. JC91006
    16,769
    8,567
    Ok, this is going to be a lesson to future buyers of Used tires........Buyer's Beware!
    I was lucky enough to purchase these tires from the seller. However I did not inspect the tires closely as I believe what he described the tires as only having 463 miles and are practically brand new.
    I went to have the tires installed today and the tire shop showed me 2 rips on the inside bead area of the tires. One had a small chunk of rubber missing (ripped out), the 2nd one actually had a good cut that shows the inner bead of the tire. The tire shop said there's a good chance the tires will leak air. I most likely will replace the 2 tires because I wouldn't want to risk the tire blowing up while I'm driving it.
    I'm sure this is nothing that the OP knew about since he's only had the tires such a short time and had them removed from the rim. It was probably caused by inexperienced tire installers/dismounters.
    Short story, the money saved is actually not saved after all. So buying used tires, sight unseen should not be done.
