Michelin's New Primacy MXV4 Tire - General Impressions
Discussion in 'Gen 2 Prius Main Forum' started by kerryjchinn, Nov 15, 2007.
  1. removeum
    removeum Member
    407
    El Paso, TX
    Re: Michelin's New Primacy MXV4 Tire - General Impressions
    :cool: I put Goodyear Comfort Tred's on both Prius that I have owned. I did not notice any hit on the mileage and they handled the weather and road conditions in and around Omaha, NE without any problems.
  2. Graz
    Graz Member
    178
    28
    I am ShOcKeD that none of you has even looked at the Conti Comfort Treads. Cost less,cget better mileage, no problem with traction, and I "think" they are quieter too.
    YMMV
  3. wolverine
    wolverine Junior Member
    Just an FYI. I was having problems with my Prius Touring 2008 pulling to the left just a smidge, so I took it to my alignment guy in Houston, who's been doing this for 30 years. He had to modify the left rear support to be able to bring the alignment within spec. Now, my car drives straight and true.
    Ehn you get your car aligned, to be proper, you must have weight in the car equal to how the car is weighted in most of its driving. For me, that's just me in the driver's seat; I'm 6'3", 220. When someone aligns my car without me in it, and then I sit in it, the wheels are no longer aligned. Try it.
    Something's wrong with Priuses that we're not being told about. You shouldn't have to jack with modifying the car to get it to run true.
  4. A. B. Hair
    A. B. Hair New Member
    57
    Rural area called Powdersville, 10 miles out of Gr
    Thanks, I have hope but I am still off about 5 mph off. I now have 1000 miles on the Primacy tires. The weather here has been mild for SC in Feb.:confused:
  5. montenido
    montenido A 2 Prius household
    23
    Calabasas, CA
    Hi all. Based on the original post, I made the switch to Michelin Primacy MXV4s in 195/60. The tires are so much better than the Integrities. Quieter, smoother, and much better handling. My MPG does seem to be taking a small hit. I am half-way through my first tank and I am averaging about 46 MPG, down from 47-48. I also added mud guards at the beginning of this tank of gas, so they may be combining with the wider tires to drop the MPG. I will take the hit for this kind of improvement in the ride. Perhaps thing will improve as the tires break in.
    Thanks for the insightful review.
    montenido
  6. A. B. Hair
    57
    I now have 2500 miles in the Michelin Primacy tires. At first I dectected aboujt 3 to 4 miles drop in mileage even with 40 - 38 lbs pressure. However, the local temp is warmer now and and my mileage has returned to normal which is around 49 mph. I am happy with the Michelins.:)
  7. gregvsandt
    gregvsandt Junior Member
    Carmel CA
    I am glad to hear about the Michelin Primacy MXV4 tires doing well. I have been in the tire business for 40 plus years and I am trying to pick the next tire for my 2008 with 1300 miles on it. The Goodyears seem to be doing just fine, quite, smooth, handle-OK, can't really complain. Looks like I will get around 40 to 50 thousand on them. I have always replaced my OE tires with a Michlein in the past and will probably pick this tire, the Primacy MXV4. I will stick with the P185/65R15 stock size, see no reason to switch to a bigger size. On the alignment side of things there is a shim by Specialty Co. to correct camber and toe on the rear of 01-08 Prius. If anyone asks, and the alignment person can't find it, its a brand new fitment. He can get the fitment online at Specialty Products Corporate Home Page. The first thing I do when I get a new car is pass it over the alignment rack and check it out, mine was out a very small amount. The rear was perfect, camber and toe, the front was out a small amount of camber. Can't wait to hear what your tire mileage is as the Michelin Primacy MXV4 is a 60,000 mile tire, but I bet you can do better as the Prius is not that heavy.
  8. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    Here in Montana we have a similar seasonal rotation, only we refer to them as: Amost winter, winter, still winter, and Construction.
  9. Doc Willie
    1,717
    142
    Out there, somewhere
    If you get a chance sometime, drive a Prius with 195s on it. Nothing else I have done to the car has made as big a difference in handling.
    Reason enough for me.
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    Good find. I had to add custom made shims (made by Galaxee's DH) to correct my rear toe problem. It is good to see that the aftermarket companies are starting to acknowledge this issue.
  11. mamamay
    mamamay New Member
    PA
    Kerry -- I just did my Consumers' Reports Research and came up with the recommendation for the Michelin Energy, but checked around and learned it's been replaced by the Primacy. My supplier has the 185/65 so based on your experience that's what I'll go with. So glad to know the ride will be quieter. Thanks so much!!!
  12. mamamay
    mamamay New Member
    PA
    Kerry, I forgot to mention that I'm also replacing the tires on my 06 Prius at 37000 miles.
  13. Spinnerbug
    Spinnerbug New Member
    28
    Lincoln University, PA
    I just installed a new set of Primacy tires yesterday on my Gen II 2008 Prius. I had Integrities and was averaging 50-52 mpg. I got 42K on the Integrities and was happy with that, but as you said they were getting worn and with the NE winters coming, I had to make a move. I paid a small fortune for them $657 mounted & balanced with front end alignment & tax.
    When I drove home I thought, boy noisy and hard...Found out this am that the dumb mechanic that mounted them put 65 lbs in each tire!
    I always use 38 front 36 rear. I have not driven it yet after I spent 15 min setting them to correct pressure. I did notice on way home that they definitely stop and grip road better and were more sure on turns...I hope now they will stop feeling like I am riding on 4 bowling balls and be like all other Michelin tires I have had in the past and loved.
    Now that you have had yours for a while, what do you think?:confused::confused:
  14. Bob64
    1,540
    92
    Virginia
    Wow 65psi. You probably got excellent mpg on your way home!
  15. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    Bringing life to an old thread. I'm leaning towards the Michelin Primacy MXV4, but am also considering the Yokohama AVID Touring-S tire (both in stock 185 size).
  16. sktn77a
    sktn77a Member
    294
    NC
    We have the Avids on our 2010 - there's no comparison, ride-wise, with the Michelins MXV4 on our 2005. If you can afford the Michelins, get them.
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    We just installed a set of the Primacy MXV4's on my wife's Honda Accord. Nice riding tire and low road noise.
    The car came with the Michelin Engergy MXV4's. Seems to be less road noise with the Primacy's and I have not seen any impact on mpg.
    I plan to replace the OEM Yokohama's on my 2010 with these same tires when the time comes.
  18. uclabruins
    uclabruins Member
    265
    Thanks for the input. I may have to get the Michelins! I think there's going to be a $70 rebate on a set of four soon, so I'm waiting for that sale!
  19. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    We put a new set of Primacys on our 99 Solara. Put them on about 12k miles ago. So far they are great. No problems at all. Would buy them again without any hesitation.
    We are heading into the summer drive season. That $70 offer from Michelin should be out real soon.
  20. uclabruins
    uclabruins Member
    265
    I pulled the trigger and went with the Michelin Primacy MXV4 in 185 65/15. I've driven about 300 miles so far the the MPGs have decreased some (around 2 mpg). The Michelins are quieter and don't squeal as much as the Integrities.
