middle vents not blowing = servo motor???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by beezer, Jun 26, 2014.
  1. beezer
    beezer Junior Member
    Columbus, Georgia
    My car: 2008 Prius (base)
    Here is the problem:
    All of a sudden the two middle vents in the dash stopped blowing. I have played with the settings - on, off, all the way hot, all the way cold - nothing from the two mid vents. The left and right vent blow with no problem. There is also cold air coming from the vent near the windshield - just the two middle dash vents are not functioning.
    What I have done so far:
    I had it looked at by a mechanic who I trust. He said there is a small motor (he called it a servo motor) that controls that middle vents (open/close). He said that had gone bad. He manipulated it so that the air blows out of the vents now and said not to change any settings until I am ready to replace the part.
    My question:
    What exactly is this part called? Are there instructions here that I have missed on how to remove/replace that part? (DIY style?)
    Thank you all in advance!
  2. beezer
    Columbus, Georgia
  3. Patrick Wong
    18,210
    6,517
    1. You can obtain factory repair manual info from techinfo.toyota.com
    2. toyodiy.com is a good source for part number info. Unfortunately it no longer has exploded parts diagrams so you'll have to rely upon the part description to decide what part number is correct.
    beezer likes this.
  4. beezer
    Columbus, Georgia
    Thank you! I have a little reading to do!
  5. Patrick Wong
    18,210
    6,517
    If you subscribe to techinfo.toyota.com then you can obtain factory repair manual info as well as a New Car Features Manual which is Toyota's effort at a "theory of operations".
    Regarding the NCF, download 2004 first, then each succeeding year will show the small differences from one model year to the next.
    beezer likes this.
  6. beezer
    Columbus, Georgia
    Will do! Thank you both.
