Mildew and stains on paint chip guard (clear coat)?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FrankTheTank, Aug 23, 2021.
  1. FrankTheTank
    FrankTheTank Junior Member
    Anyone seen this before? I assume I have to peel it off to clean it since I have tried every type of cleaner out there and nothing seems to work. In retrospect I am not sure if these extra guards were worth the money back when I bought this car new in 2012.....
    Thanks
  2. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Dang, was that clearcoated? If you can't get it off, you may just want to put down a protector, I have these on our 2017 and 2021 Prius'...
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Yes. It is "upsell" junk.
    When mine was in the body shop for a minor "ding", I had them take all of it OFF.
    I don't think they even charged me to do that.
  4. JC91006
    16,480
    8,397
    If the chemicals used were too harsh on plastics, it could destroy it. If removing it, you might need to heat it up as you peel it off the bumper.
    Useless options are always a way the dealer can make more money. Especially in today's crazy hot market, every car is loaded up with crazy options. Even if you buy the car at MSRP, the useless options will make the car way more expensive than it should be
    Raytheeagle and FrankTheTank like this.
  5. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    I recommend obtaining a product called Bestine (heptane), available on Amazon (expensive) or at art supply stores (less expensive...) and places like Staples. It is an organic solvent which will NOT affect paint or almost any plastic (including your problem). It will only attack the organic solvent holding the plastic to your bumper. Just work it in a bit at a time with a dropper or a paper towel (it's quite volatile, so you'll have to keep adding it). I've used it for about 40 years to good effect.
  6. Mendel Leisk
    38,707
    This makes me think about those small zones of plastic overlay, on the rear side door openings.
    one time I parked under a tree that was dripping pitch. What worked, albeit with a fair bit of elbow-grease, was a rag soaked (and wrung out) with kerosene, plus a dab of car polish.
    #6 Mendel Leisk, Aug 23, 2021
  7. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
    No need to remove it. Just get a spray paint can of white plasti-dip paint (aka: peelable paint) and spray it on... It is a very thick fast drying paint and takes touch ups spray on damage really well. It also peels off entirely if you want to put on a new coat.
