Mileage and Avg Speed Readout Not Right
Discussion in 'Gen 3 Prius Audio and Electronics' started by [email protected], Aug 1, 2021.
  1. Racerman15@comcast.net
    [email protected] Junior Member
    32
    San Francisco
    2020 Prius
    2013 Prius. The mpg bars are correct but the mpg readout and average speed on the dash are not correct. Is there a way to reset it?
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    hold the trip button til the values are zeros.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What exactly do you mean by "not correct" ?
    Those numbers all tend to be off a bit, maybe 10% would be considered "normal".
    52,831
    how can you know if the average speed is not correct?
    and how can you match up the running average of the mpg's to the fluctuating current mpg bar?
  5. fuzzy1
    10,705
    About the only easy way to check it is to set a highway cruise control speed, then reset a Trip meter, then see what average speed displays while cruising at a single speed.
    And even then, one needs to remember that the speedometer display itself is not correct, but reads slightly high. I'm seeming to remember a few other readers discovering that the Trip average speed doesn't have the same built-in error as the speedometer.
    An alternate but more involved way of checking average speed display would be to reset a Trip meter and start a handheld GPS trip at the same time, and compare. This would allow checking on trip segments with varying speeds. Just be sure to use the GPS's overall average speed, not 'moving average'.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Drive 60 mph for 3 minutes, stop stationary for 3 minutes, avg speed will be 30 mph.
    Below was last week's tank, the average speed is incorrect.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    You are approaching a hill.
    It is a half mile to the top of the hill.......and a half mile back down the other side.
    If you go UP the hill at 30 MPH, how fast must you go down the other side to average 60 MPH for the whole trip over the hill ???
  8. fuzzy1
    10,705
    c.
  9. bisco
    52,831
    none of the above
