Mileage declining at 23,000 miles
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by csk47, Jun 19, 2019.
  1. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    My 2016 Prius Two had been getting 54 mpg since we bought it until about three months ago. The car never leaves south Florida and I drive in the same traffic conditions on community roads every day. Now the mileage is down to about 44 mpg. I bought new tires recently but the drop was happening before then. It just seems that the battery level doesn't stay up as much as it did and the engine kicks on more. I am bringing it to the dealer next week for an oil change but I don't want to be sold work I don't need for the mileage problem which seems more batteries than gas engine to me. Do I need injector cleaning? Can they run some kind of a diagnostic check to show the cause? Any advice is greatly appreciated.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The engine running more frequently and the battery level not staying up are totally unrelated to injector cleaning, which in any event should not be required at 23,000 miles.
    Note that if there is a problem with your hybrid battery or related control systems (ECU), this will be covered under warranty. Typically the dealer won't offer up warranty work first.
    #2 jb in NE, Jun 19, 2019
    52,863
    at 23,000 miles, the only things it needs is oil and filter every 10k, air and cabin filters inspect/clean/replace at 30k and 15k respectively, tire rotation every 5k, and a bunch of inspections.
    are you tracking your mpg's manually calculated by the tankful at the pump?
    are you using the a/c a lot more?
    where did you buy it, are they reputable?
    why did you replace the tires so soon? what did you put on?
    what tires pressure are you running?
    the dealer can't help because you don't have any trouble lights on.
    check the 12v. a low 12v can reduce mpg. check the oil level too.
    kithmo and Mendel Leisk like this.
  4. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    The big one I'd look at is the 12v battery. It is a common issue that when it begins to fail the mileage starts to suffer.
    kithmo and PriusGuy32 like this.
  5. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    I will check the oil level and have the dealer check the 12 v battery. Thanks for your help...
  6. bisco
    52,863
    pleasure
  7. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    I just checked my 12 volt battery that has been sitting overnight. The reading was 12.35 volts. That would indicate the battery is okay?
  8. bisco
    52,863
    borderline, but poly not the problem.
    at that voltage, i would swing by auto zone for a free load test. is it original?
    fyi, a new agm battery, fully charged is 13v.
  9. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    Yes, it is original. I find I get better help on this forum than calling the service "experts" at the dealership. Will go to Auto Zone. Thank you for your help.
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    Not on a 2016!
    I have more miles than that on my 2017 with no issues (approaching 30K)
  11. Prodigyplace
    12,715
    11,848
    Central Virginia
    Gen 4 is not agm , but an unusual size.
  12. Mendel Leisk
    42,355
    Battery health depends on a lot of factors. A car seeing very light use is prone to have battery problems sooner.
    I suspect the designers have a checklist, and one item is to ensure the battery is rare or expensive, preferably both.
    kithmo, bisco and Prodigyplace like this.
  13. bisco
    52,863
    sorry, i knew it was gen 4 in the beginning, but as it goes along, i keep spotting the 2010 in the vehicle data.:p
    12.35 is probably fine. still worth a load test, but i suspect another issue.
    problem is, on an almost new car, the usual suspects don't come into play.
    Prodigyplace likes this.
  14. Prodigyplace
    12,715
    11,848
    Central Virginia
    Welcome to the club! :D
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Port St. Lucie, FL
    Any chance your A/C is working harder? Here in MS, we are in a season you see on your oven.
    audiodave and Mendel Leisk like this.
  16. bisco
    52,863
    see post #4. come on jumbo, get with the program. you have to read the whole thread
  17. Prodigyplace
    12,715
    11,848
    Central Virginia
    OK, 2 errors
    Post 3
    Jimbo
    bisco and krmcg like this.
  18. bisco
    52,863
    sorry teach!:cool:
    Raytheeagle and Prodigyplace like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Still one of the better auto corrects out there:p.
  20. Prodigyplace
    12,715
    11,848
    Central Virginia
    I wish I was as detail oriented in my typing. Programming languages are harsh critics.
