Mileage declining at 23,000 miles
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by csk47, Jun 19, 2019.
  1. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    Update on mileage problem: I had an oil change last week and the car was tested to see if there were any issues that would affect mileage. The service person no codes came up so they have no clue why my mileage dropped from 54 mpg to 45 mpg. I did buy a set of Continental True Contact tires in that time but my mileage was slipping before I put them on. Does anyone have this exact tire and what happened to your mileage? These Continentals were supposed to be very good for gas mileage..that's the main reason I bought them over other tires for a Prius. I'm trying to decide if I want to pursue the poor mileage or just chalk it up to the tires.
  2. Mendel Leisk
    42,381
    Not that tire, but I did a tire replacement earlier this spring, with Green-X rated Michelins, and am just now starting to crawl back out of the mpg basement. The new tires are excellent otherwise, but I did take a bit of a hit. A few months later I'm getting optimistic that they are breaking in, and the mpg is coming back.
    I have had tire replacement where I didn't skip a beat, but I guess what I'm saying is: it can be the new tires, regardless of their rolling resistance ratings, and then it just takes some patience.
    I hope...
    #22 Mendel Leisk, Jul 1, 2019
    krmcg likes this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Did they put the correct 0W20 oil in, some have reported a hit in mpg if the dealer uses 5W30 (or thicker) instead.
    Prodigyplace likes this.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't think that either oil or new tires will account for a 20% mpg drop.
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    A lead foot on the accelerator might though ;)
    kithmo likes this.
  6. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    I am 71 and no longer drive with a lead foot. Nothing at all has changed about how and where I drive from when I was getting 54 mpg to 42 mpg most recently. I keep reading in various forums about how the 12 volt battery can cause a loss of mileage but my car is barely 3 years old with 23,000 miles.
  7. audiodave
    audiodave Active Member
    800
    272
    US
    If you have a trickle charger you can try charging the 12v once or twice a week. Otherwise try 40 psi front and 38 rear on the new tires. Just a little higher then what you have.
  8. Mendel Leisk
    42,381
    I put ours on a smart charger pretty much every day there's likely to be no use of the car, and just leave it on till next usage. A quick-connect makes it more convenient. Appreciate this doesn't work well for people street parking or condos.
  9. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I put Continentals on all our cars ... all the 16's have them now ... all Four Touring Models. Typically we take a hit from the older hard tired to the new soft with lots of tread .. it's normal.
    Make sure the Continentals are properly filled .. we run them in the 33 range. They have softer side walls vs some other brands.
    My favorite All Season tire brand .. have them on the SUV's -- Hybrids ... Euro's ... love them.
    krmcg likes this.
  10. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Any new tire will reduce efficiency; even if it's a low rolling resistance tire, it still has higher rolling resistance than the worn tires you replaced. Rolling resistance decreases as tires age and as their tread is worn away.
    I have the same tires, going on 35,000 miles on them.
    Edited to add: At the 2018 Green Grand Prix my car returned 62.8 mpg; at the same competition, on the same track, at the same time of day in 2019 it only got 59.2 mpg. Was something wrong with it? Of course not: in 2018, the weather was overcast but not raining with temperatures in the mid-60s, while in 2019 it was 32 degrees and sleeting; even in a closed competition like that, the traffic of 40+ other cars was different each year, in many unpredictable ways; I had a (200+ lb) passenger in 2018 and none in 2019; etc. Even if you think everything is the "same" it never is; there are way too many variables in daily driving. The question is, are those variables enough to explain the drop in one tank's mileage? They certainly could be. I would give it two more tanks, and if they are as low, then you can be reasonably certain there's a problem with the car itself (or the way you are driving it) and it isn't just a product of the natural variability in traffic, weather, wind, route, trip lengths, and so on. My 2 cents.
    #30 Vman455, Jul 29, 2019
    krmcg likes this.
