Mileage in 20s???
Discussion in 'Gen 3 Prius Fuel Economy' started by shankyyy, Dec 15, 2010.
  1. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    What kind of BMW was it? I find it hard to believe a BMW( all i can think of is v8 sporty cars) can get over 16mpg running at speeds over 100mph.
  2. Former Member 68813
    3,524
    983
    US
  3. adamace1
    1,403
    193
    Charlotte, NC
  4. Former Member 68813
    3,524
    983
    US
    It all depends how cars are geared. If M3 has a very tall top gear, the engine could loaf at 100 MPH. I don't know what RPM Prius runs at 100 MPH, but I bet it's high. It's not made for high speed driving.
  5. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    SO, the bigger question to be answered is, is PRIUS better for short trips and less mileage, or relativley longer trips with higher mileage? In the former, you drive less and consume less gas, but in the latter you get higher mileage, so the cost/mile is lesser here.
  6. ChiTownKel
    ChiTownKel New Member
    I have the same problem...just bought my 07 Prius last week. Half a tank gone and all I'm getting is 22 mpg, city and hwy. Very disturbing! I park outside and its winter now in Chicago. Temps are subzero to about 30 for the past week. I warm it up for 5 mins while cleaning snow off. I have the heat set to MAX b/c I need the warmth (takes forever to warm up seems like). I use cheapest gas to fill it up - should I be using better gas?
    I drive "pulse and glide" style while watching the computer display. It SAYS I'm getting 65 mpg and 99 mpg often - but the reality is that I've gone through a half tank of gas and only driven 100 miles. Wondering what I'm doing wrong. Please help. Thanks.
    NOTE: my car is at dealership now, getting recall stuff done while still under its 3 year warranty. Anything I can have dealership do to get better mileage?
  7. fuzzy1
    10,719
    Compared to regular cars, Prius is better for both kinds of trips.
    But for the shorter trips, a Nissan Leaf will be even better than a Prius.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Start reading here. All of this stuff has been gone over a million times so hopefully you'll find this useful.
    http://priuschat.com/forums/gen-ii-prius-fuel-economy/14701-new-owner-want-mpg-help-read-first.html
    Also look in the GenII Fuel Economy section as the information is just as relevant for the GenIII. :)
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Some of us find warm-up for 5 minutes disturbing.
    Thankfully, we can all find comfort that winter doesn't last forever. Warmer weather returns in a few months, the MPG shoots up. So, you're still using less gallons-per-year anyway.
    Of course, this begs the question of what your previous vehicle delivered.
  10. ChiTownKel
    Thanks all. I've been lurking here for a while reading as much as I can about hypermiling before taking the plunge of buying a Prius.
    My old car was my feet :) so I was really banking on the Prius getting 45 to 60 mpg right off the bat, so as not to feel too guilty about driving. 22 mpg is pretty sad.
    Could running the radio be contributing to my bad MPG??? Asked dealer to inflate tires to 40 PSI but they said you can't inflate past 35 PSI.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    22mpg is about the worst I've ever seen on a Prius and that includes those living in extreme climates. I would suggest running a full tank and see how your mileage works out. If it continues to be horrid then look into grill blocking, engine block heaters and combining trips so you are not constantly in and out of the car. I was forced to run a bunch of short mileage errands this weekend and it wrecked the MPG on this tank.
  12. fuzzy1
    10,719
    The Toyota factories can certainly inflate to 40 psi, and my dealer didn't bother to lower it.
    While traveling, and over my objection, a different dealer lowered it to 40 psi, highway hot at 6000 feet. Unfortunately, cold at sea level, that becomes several psi underinflated.
