Mileage in super hot weather?
Discussion in 'Prius v Fuel Economy' started by art_vandelay, Dec 18, 2013.
  1. art_vandelay
    art_vandelay New Member
    So, I've heard Prius gets better mileage in warmer weather. I live in Phoenix though, where highs regularly exceed 110 fahrenheit in the summer. At that point, doesn't mileage start to decrease (either by virtue of A/C working overtime, or just decreased battery performance)?
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Art_Vandelay -The Prius Hybrid Synergy Drive delivers the best fuel economy in warmer climates, like Deep-South Dixieland, Florida, Hawaii, AZ, NM, NV, SoCal and TX, at the time during the year when the daytime outside ambient air temperatures (OATs) are in the low 60s to low 80s (Fahrenheit) range most of the time. Warm outside ambient air temperatures serve to shorten the duration of the warm-up period and length of the "thirsty" Initial Start/Restart “Rich-Burn” Mode of fuel consumption.
    Once the OATs drop below or rise above this “Happy Hybrid” operating range, air conditioner or heater use works to lower running MPG.
    Of course, this “Hit” to MPG in Hot-Cold operating environs is true for conventional, ICE-Only powered vehicles.
  3. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    So, what is the typical MPG-"hit" for temperatures exceeding 100ºF?
  4. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Can you live without air conditioning?
    iPad ? HD
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    I have no trouble getting 47, its certainly far better than in freezing temps. Using ECO mode helps. The AC isn't as hard on MPG as some folks around here would have you believe.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am going to jump in here and urge you to get lower MPG.
    The same A/C that keeps YOU cool and comfortable is cooling your batteries and keeping them comfortable and longer lasting. Do not skimp on A/C.
    (Frequently, it is not the heat, it is the humidity. I was a fry cook in Phoenix, it was the heat)
  7. 70AARCUDA
    845
    209
    Tucson, AZ
    ...and the Devil sighed, "...yes, but it's a HUMID heat during our monsoon Hades season..." (wink,wink)
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  9. 70AARCUDA
    845
    209
    Tucson, AZ
