Mileage w/ECO Mode (Houston-Ft Stockton)
Discussion in 'Gen 3 Prius Fuel Economy' started by DoubleDAZ, Jun 6, 2015.
  1. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Not sure what to make of these numbers, but I thought I'd post them to add to the discussion about using or not using ECO mode.
    Back in January, we drove from Phoenix AZ to Cocoa Beach FL and got the following mileage between Ft Stockton and Houston. I did not use ECO mode on this trip.
    Ft Stockton to Selma 34.8 mpg @ 68 mph
    Selma to Houston 39.3 mpg @ 67 mph
    Avg 36.3 mpg
    Just last week, we drove from Richmond Hill GA to Phoenix AZ and got the following mileage between Houston and Ft Stockton. I decided to try using ECO mode for this trip.
    Houston to San Antonio 46.1 mpg @ 70 mph
    San Antonio to Ft Stockton 39.5 mpg @ 77 mph
    Avg 41.8 mpg
    Note: San Antonio and Selma are essentially the same, just different service stations along Hwy 1604. Cruise control set at 2-3 mph over the limit was used wherever possible.
    I realize these trips were in opposite directions and at different times of the year, so I'm not sure how much the wind/cold in January may have affected the first set of numbers. However, I'm encouraged that even running up to 9 mph faster, I was able to get 5.5 mpg more using ECO mode. We will be making the trip back to Richmond Hill GA next month and I'm going to try to duplicate most of the 2nd trip to see what numbers I get then. I'm already semi-convinced that using ECO mode results in 3-5 mpg more, but I have to say that there were times in traffic when ECO mode left a lot to be desired, though I muscled through without switching it off. I don't have a regular commute, so it's very difficult to make many comparisons and draw conclusions, so I'm left with subjective opinions. :)
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    The ECO mode has little if any effect on mileage. It simply changes the accelerator sensitivity. In ECO mode you have to push the accelerator further to get the same amount of power as when the ECO mode is off. If you have a "heavy foot" the ECO mode may tame you down a bit :)
  3. Mendel Leisk
    38,729
    The waters get muddied by what ECO is (or isn't) doing, with things like cruise control sensitivity, AC performance. But in the main yeah: ECO just modifies gas pedal travel and result, makes it harder to get a reaction. Overly so for me, don't use it. Well, I did for about the first 3 months. Then left it off while we were on a road trip vacation, didn't see any difference, so left it off.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I preferred eco. Hardly ever take it out. On my second over 1000 kil. tank driving in eco at present. It just makes it less effert to do good numbers. Our gas prices just hit $ 1.27 per liter . Holiday fokes so they have to get greedy again. Dam oil companies. H
  5. Mendel Leisk
    38,729
    Ours just dropped to $1.27. Big city prices, lol.
  6. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Sorry, I know what ECO mode does and didn't say it alone increases mileage. However, saying it has little affect on mileage is misleading IMHO. While it doesn't directly affect mileage, it helps many drivers accelerate more slowly because of the reduced accelerator sensitivity without having to think about doing so or watch the display, etc. I found it particularly helpful in heavy traffic to keep from constantly accelerating/braking. The reduced sensitivity kept me from accelerating only to hit the brakes and the drive through Houston and San Antonio traffic was more relaxed during this trip. Obviously, if one presses the accelerator that much harder, turns the A/C fan speed higher, etc., it negates the effects of ECO mode and is basically useless. However, since I'm not in a hurry, use cruise control on the highway, etc., it seems to have helped me increase my mileage and that's my only point. Use it or don't use it, makes no difference to me. I intend to use it on our trip next month to get some more data to analyze and then decide what to do in the future.
    #6 DoubleDAZ, Jun 7, 2015
  7. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I can appreciate that. I didn't like it when I experimented with it when we first bought the car last year, it was enough just to get used to the reduced power of the Prius. But now that I'm used to that, I no longer find ECO mode all that bad. Different strokes I guess and I still might go back to not using it.
  8. Mendel Leisk
    38,729
    Yeah, if you have something empiracle, a daily commute, try resetting trip B day after day, with/without ECO. With ECO I almost found it harder to control, there's a certain range of muscle contraction that's easy and controllable, if you have to exceed that range you tend to get more erratic. Well that's my theory, anyway, haha.
  9. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    And that first part is the key point. If you are already adept at getting good numbers, ECO mode probably won't do much, if anything, for you. I just drive the car, so ECO seems to have helped me get better numbers and that's my only point.
    I was surprised to find that gas prices here were some of the more expensive on the trip at $2.699/gal. I know that's cheap compared to yours and I understand that we switched over to the more expensive summer blend, but it's still frustrating to see prices fluctuate the way they do and see them vary so much across the country.
    HaroldW likes this.
  10. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Unfortunately, no regular commute, so empirical data just isn't in my future. When I tested ECO mode the first time, my experience was basically the same as yours. But now that I've gotten used to the Prius, I'm not having the same experience. I have actually grown to like the reduced response of the Prius in general and don't much care for driving my truck or faster cars these days. I find the slower pace of the Prius to be more relaxing and it just fits my current driving style, especially on trips. ECO mode isn't that comfortable in stop and go traffic though, so I do turn it off at times.
    #10 DoubleDAZ, Jun 7, 2015
  11. CaliforniaBear
    1,179
    289
    Northern California
    Thanks for the detailed explanation regarding my statement. "If you have a "heavy foot" the ECO mode may tame you down a bit".
  12. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I just completed a round trip to Erie, Pa from Dallas, Tx. On the way to Erie route was up thru Ok,Mo,ind,and Ohio , mostly flat running. Tires at 40/40 speed 75 to 85 mph. Got 47 mpg. On the way back southern route thru Ky, Tn, Ar. A lot more hilly and mountains. Back loaded with about 400 lbs we didn't have we didn't have on the way up. Tires at 35/35 lbs. .Got about 44 mpg. Ride much smoother and quieter. No diff. in handling at 75 to 85 mph. Excellent wet traction both to and from Erie( rained hard there and back.) Diff in mpg I think was from hilly route and extra weight. Notice smother ride now with extra weight gone. Absolutely no diff in city mpg from 40/40 to 35/35 psi.195/65-15Yokohama AVID Ascend tires with about 10,000 miles on them. Used cruise control as much as possible and did not use ECO mode Just in normal mode. Drove it like i would any other car.
  13. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I've often wondered about the tire pressure at highway speeds. After we get to Georgia on our next trip, I might reduce mine to what's on the door and see if/how it affects mileage on the way back home. Like this post, the test won't be scientific, but it may still tell me something.
    lar.smith42 likes this.
  14. HaroldW
    716
    95
    I'm running my Ecopia ep 20 @ 35 -34 with the same fe. Tires may not last as long, but the car feels much more comfortable. H
  15. Mendel Leisk
    38,729
    I've taken our 215/45R17 Michelin Pilots down a bit, from 36~38 psi, to 34 psi all around. This is pretty close to the recommended pressure for the 17": 33/32 f/r. Fuel economy doesn't seem to have suffered. I suspect it has a bit, and with weather warming it's masked a bit. But the 17" have a rough ride, and it's nice to smooth out a bit. Also, I think it's less stress on suspension, bearings, etcetera.
    #15 Mendel Leisk, Jun 8, 2015
    HaroldW and lar.smith42 like this.
  16. HaroldW
    716
    95
    Well I'm at 925 kilometers and two pips left. Looks like another 1000 kil. tank. All on eco. Works for me. H
  17. Mendel Leisk
    38,729
    Yeah, but you could do that in PWR mode, Harold. :ROFLMAO:
  18. HaroldW
    716
    95
    Yes, probably Mendel, but I'm happy with eco mode. Retired and in no hurry! H
  19. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Nobody, (or at least I didn't notice anyone) talked about the effect of head winds, they can really screw up your highway mileage.
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Using power mode, 2010 Prius, I get the same mpg as eco. Also if you use your computer readout for mpg it will be off at least 3 mpg; so 45 mpg on computer dash readout is 42 mpg actual. My mpg during June is (calculated) 57 mpg computer readout 60.1.
