Miles on yer Gen 3? (& major work done?)
Discussion in 'Gen 3 Prius Main Forum' started by CharlesPrius, Jan 12, 2019.
  1. CharlesPrius
    CharlesPrius Member
    154
    60
    38-41, ouch
    Soujiro13 and Mendel Leisk like this.
  2. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    2010 Prius 2
    260K Miles
    Change oil somewhere between 5-10K, uses 1/2qt in 10K miles.
    Trans fluid every 60K
    Coolant every 100K
    Tires every 70K
    Plugs and EGR clean at 192K
    Both rear wheel bearings around 200K
    Original 12V and traction battery
    Installed LED headlight bulbs at 220K miles, finally no more replacing bulbs every 6 months.
    I would love to have a new Prime advanced, I personally like the look other than the white interior on some of them.
  3. Mendel Leisk
    42,361
    ^ That's a keeper. (y)
    m.wynn, Bay Stater and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    We probably all feel the same way about each of ours;).
    I do about mine anyway:).
    It’s primed for the @bisco challenge(y).
  5. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I have a little over 80K miles on mine. Normal maintenance items oil, tires, one set of front brake pads around 50K, I do the cabin and engine air filters myself. Major repairs were three wheel hubs, one rear brake caliper, and a new hybrid battery. So far so good, the engine doesn't use any oil between my six month oil changes.
  6. Tande
    Tande Active Member
    556
    339
    Mich.
    In 80,000 mi. ??......:eek:
    CharlesPrius likes this.
  7. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Yep the three wheel hubs and the real caliper were all within 60K miles. I got the your battery is deteriorating code at 73,500 miles and the dreaded your battery is dead replace it, at 78K miles.
  8. Mendel Leisk
    42,361
    Yeah until something real expensive fails, those brake components on the firewall for example, ugh.
    m.wynn, Bay Stater, ALS and 1 other person like this.
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Still cheaper than a new car;).
    And if low mileage like your garage queen, I’d sink some more into it(y).
  10. Mendel Leisk
    42,361
    Agreed, wholeheartedly.
  11. Tande
    Tande Active Member
    556
    339
    Mich.
    OMG! ......
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    That’s the hilly salt belt for you:eek:.
    m.wynn and Bay Stater like this.
  13. CharlesPrius
    CharlesPrius Member
    154
    60
    I'd say you're the winner so far! Which LED's did you buy?
  14. CharlesPrius
    CharlesPrius Member
    154
    60
    Yeah my $1500 HeadGasket + Water Pump job was well worth it, it runs better than ever and I'm currently getting 53-56 mpg, the best ever.
    Bay Stater, RMB and Raytheeagle like this.
  15. Stangar
    Stangar Active Member
    174
    175
    Palmdale, CA
    2011 Prius 3 - original owner
    202,000 original miles
    Tires: 105K miles on original Yoko's and 97K miles on Michelin Energy Saver A/S (and they'll easily go another 20K)
    51 to 54 mpg (calculated) mainly highway
    Oil change every 5K miles with Mobil 1 5W-20 (doesn't burn any)
    Tranny fluid every 30K miles with Toyota ATF WS
    Cleaned EGR cooler and installed OCC (oil catch can) at 185K miles (and it needed cleaning badly)
    Plugs at 105K (I need to change them again)
    New struts and shocks at 155K (and should have done it sooner. They were shot). That kicked my tail in the Summer heat.
    One new 12V battery - Original was still good after 7 years - preventative action
    One brake fluid change at 145K along with slide pin lube
    Environment: High desert of Southern California
    I drive the speed limit (65 and 70 mph) in the right lane. "Heh, you are holding us all up!"
  16. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    My 2010 was totaled Dec. 29th, 2017. Like most here, nothing major to report other than a bunch of over-maintenance:). This summary copy/pasted from a thread 1 year ago:
    - literally a couple hundred miles shy of 150k miles, I never got to truly "own" the hybrid battery which was still performing solidly
    - zero oil burn, TGMO 0w-20 at 5k mile intervals from new, never varied once from this protocol
    - transaxle fluid changes at 87k, 97k and 140k
    - both coolant loops drain/fill twice
    - Intake manifold EGR ports cleaned at 97k, fully gooked and low rpm acceleration "shudder" prompted
    - driver side transaxle seal at 97k
    - front pads and rotors at 100k
    - rear pads and rotors at 115k
    - original wheel bearings
    - plugs and PCV at 130k
    - entire EGR circuit cleaned and preemptive water pump replacement at 140k
    - Winston Chin's ETC spoofer
    - Energy Savers summer, x-Ice 3's winter
    - H11 to H9 low-beam mod
    - LED parking, interior and rear license plate bulbs
    The plan was to stay ahead of oil burning/EGR/head gasket issues and go for "gen 2-style" mileage. Will start over now with a 2014 just picked up Saturday (Jan 13, 2018).
  17. High Mileage
    136
    238
    2018 Prius Prime
    CharlesPrius, I purchased the Hikari kit for the H11 6K cool white bulb on Amazon in Dec 2017 for $70. They have done well for me so far.
    Bay Stater and Robert Holt like this.
  18. nownow
    nownow Junior Member
    70
    Pinehurst NC
    150k (about 120k ours) on a 2012 Prius Three.
    - Changed the low beams twice.
    - Changed the transaxle fluid at 125k
    - Oil changes at 7,500 with Pennzoil Platinum 0w20 (now high mileage).
    Taking it in tomorrow for front brakes and a brake fluid change. Since I'm dropping it off I may see what they want to change both coolant loops and the water pump. Probably do an EGR this summer. It might be losing 1/2 qt over 7,500 miles, maybe.
  19. Soujiro13
    Soujiro13 Junior Member
    Yup cleaned it thoroughly, definitely did improve from the 34-36 was getting prior to cleaning. It's weird though, once in a while I will easily get 44-46 mpg. Can tell the system is kicking in easier. Driving habits stay similar.
  20. MichaelT
    MichaelT Junior Member
    Minneapolis, Minnesota
    I am up to 370,000 miles on mine with no major repairs needed!
