Miles per gallon Stuck at 49.2!
Discussion in 'Prius c Audio and Electronics' started by bob goldstein, Feb 2, 2018.
  1. bob goldstein
    bob goldstein Junior Member
    Cupertino, CA
    2014 Prius c
    And my Driving Time is 89 hours!!
    How to reboot the computer that controls all this? Did I do something to cause this??
  2. Davidboats
    Davidboats New Member
    Orlando Fl.
    The only easy way to reboot is disconnect 12 v battery in trunk. Remove negative lead for a few minutes then re attach. That should reboot computer. My readout display on dash also can toggle between energy consumption and energy usage. there is a reset in the screen try that. good luck.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    The trip a and trip b roll over at 10k miles, so if you're over that, it will still reflect the old MPG and time, but it will show the lower set of miles. Reset the trip and it will show the shorter mileage.
