miles to station dont updates
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Jan 31, 2013.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Fill up the tank when I had 20miles to go but the figure is not changing, still going down, I'm at 9miles. Ideas?
    2010 gen3.
    Thanx
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Did you fill the tank, or just add a little bit? If you just add a little bit, the display won't update.
    (Probably because it's hard for the car to tell exactly how much is in the tank, as the reading changes while you move, and while the car is pointed uphill or downhill, etc. So it can't tell the difference between the car being on an incline and adding a gallon or two, but it can tell when you fill the whole tank.)
