Milestar MS932 Sport Tires
Discussion in 'Gen 2 Prius Main Forum' started by oldtechaa, May 13, 2019.
Tags:
  1. oldtechaa
    oldtechaa Active Member
    336
    223
    NZ
    2013 Prius Alpha
    I wanted to share my experience with Milestar MS932 Sport tires. I originally had Michelin Defenders on my car when I bought it, but they were losing tread and I didn't want to go through the winter on them. I found these tires on Tires Easy for $42 each with free shipping, made by Nankang. They are warranted to 50k, although I care more about the UTQG score of 540. That is a great value compared to nearly every other tire.
    I was concerned about the mileage dropping with such a cheap tire, especially versus the excellent Defenders. As I entered the winter with Defenders, I was at 48.2 and dropping. As I exit the winter with the Milestars, I am at 47.4 and climbing. Milestar rates the tires as a 9.5 for efficiency, I believe, and it seems to be accurate.
    The traction is good; I haven't really lost traction anywhere I wouldn't expect it. I was running 40 psi, but I've now dropped to ~37ish. All-in-all, they are great tires in nearly every way, and seem to be holding up pretty well.
    51,141
    you can't beat the price!(y)
  3. oldtechaa
    336
    223
    NZ
    2013 Prius Alpha
    The only tires that I've found anywhere comparable in value are:
    • Yokohama AVID Ascends for $65-70 with 80k, 800UTQG and fewer installations to pay for over time.
    • Walmart Douglas tires, also around $44 with 480UTQG? with cheap installation at Walmart, but with unknown traction or rolling resistance, which could massively change the TCO.
    51,141
    yeah, i paid $130. for my michelins
  5. Salamander_King
    Salamander_King Senior Member
    11,009
    8,934
    New England
  6. HoyK
    HoyK Junior Member
    Have you tried the Waterfall Eco? How was the MPGs on these tires?
  7. Salamander_King
    11,009
    8,934
    New England
    Nope. I have not tried Waterfall Eco on my PP yet. As crazy as it sounds in today's market, for me in the past 5 years, it has been cheaper to buy a new car than buy a set of tires since the time I posted about Waterfall Eco. Back then, I thought I would be keeping the 2017 PP I owned longer needing to buy a set of new tires to replace the OEM tires. I may give them a try if I keep my current car (21 PP) long enough to need a new set of tires, though I am doubtful that will happen from natural wear. I drive less than 6K miles/yr on my PP OEM tire now. I will be likely to be trading in the car before needing to replace tires on it.
    #7 Salamander_King, Sep 12, 2022
  8. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    I picked for performance instead of economy, got sumitomo HTR A/S P03 and love them. Getting mid 40s mpg and have yet to make them squeal. They just stick, makes the car handle great,
