Millage left after fill up?
Discussion in 'Gen 3 Prius Fuel Economy' started by mroe1, Nov 3, 2016.
  1. mroe1
    mroe1 Junior Member
    22
    Phoenix, Arizona
    It use to say 500 plus miles till empty after I fill up, now it says a little over 450, way would I get different mileage. Does some kind of tune up need to be done?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius? Has any recent work been done to the car that could affect mpg ( new tires, brake work, etc.).
    What is the mpg that is being displayed?
    52,863
    no, it doesn't really know how many miles you can drive on a tank. it uses your history for the calculation. your driving will determine how far you can go.
    a better indicator of how your car is performing is manually calculating and tracking your mpg's at each fill up. that's a good time to check the oil and tyre pressures too.
  4. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    DTE is based on previous MPG so I suspect that your MPG is falling off slightly. That could be attributed to colder weather, winter fuel blend and other similar factors.
    BethPet and Raytheeagle like this.
  5. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Very good common sense.
  6. Mendel Leisk
    42,355
    Yeah, don't count on Toyota for meaningful (and honest) info, do your own calculation, it's the only way to roll.
  7. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    after putting in 40lbs of pressure and using the mobil1 hybrid formula "green cap" and mobil1 extended filter. My mile are almost back to normal for the winter season.. as of last night was fantastic for my commute home for further proof of decent milage. I live in NJ .. 20161103_185335.jpeg
    SM-G935T ?
  8. Mendel Leisk
    42,355
    If keeping logs and doing calculation is not happening, at least Toyota's mpg bias is fairly consistant: in my experience with third gen, if I take the value in the dash and multiply (multiply for liters/100 km, divide for mpg) by 1.075, I'm in the ball park.
    Phatlife likes this.
