Miller Cat Shield for 5th gen Prius
Discussion in 'Gen 5 Prius Main Forum' started by SupersonicPrius, Jun 26, 2023.
  1. SupersonicPrius
    SupersonicPrius Junior Member
    39
    55
    Colorado
    2023 Prius
    I recently ordered the stainless steel version of the Miller Cat Shield for our 2023 Prius through the dealer, and it has arrived. Has anyone installed it yet? I installed cat shields on our Toyota Land Cruiser which was easy because it sits up so high and doesn't need to go on a lift, but with how low the Prius rides, I can't imagine it would be possible without lifting at least the front and also likely the back as well which doesn't sound appealing to me. I requested an appointment at the dealer later this week, so unless I hear it's super easy I'll probably just have the dealer take care of it.
  2. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    I believe I read here somewhere they moved the Gen 5 Cat up into the exhaust manifold assembly to thwart cat thieves...
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,551
    2,593
    Taylors, SC
    Should be the same difficulty level as the Land Cruiser.
  4. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    I can't really put it on ANY scale of difficulty. I believe that once you install it, you'll be embarrassed you even asked. It's that simple.
  5. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    True that Toyota did but imho, I'm not confident that the crackhead thieves are smart enough, or aware enough to know what is what. I expect them to be willing to hop under almost any car they can and cut out anything that remotely looks like a cat.
  6. Downrange
    373
    214
    2024 Prius Prime
    SE
    After they hotfoot off with a few worthless resonators, maybe they'll learn.
  7. SupersonicPrius
    39
    55
    Colorado
    2023 Prius
    Haha! I'm not worried about the install...just fitting underneath the car! I'll see if my ramps could work to get it high enough off the ground. That might be the ticket!
    HoustonEvolution likes this.
  8. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
  9. SupersonicPrius
    39
    55
    Colorado
    2023 Prius
    Ronnie5 likes this.
  10. Skyisfalling
    Skyisfalling New Member
    So Cal
    2023 Prius Prime
    SE
    Has anyone tried to crawl under a Gen 5,,,seems much lower than previous Gens.....unless they bring a jack, it will be tough to steal the cat...
