Mini VCI tech stream version 7.30
Discussion in 'Gen 2 Prius Technical Discussion' started by boppo, Mar 27, 2013.
  1. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I can get this with the cables and cd's for 44 bucks. Is this a good deal and will it work on my laptop for my 2006 Prius?
    Thanks
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
    That's without the cd.
    I guess my question would be who has bought this product and how much was it and where did you buy it?
    Thanks
  4. lopezjm2001
    1,146
    407
    Sydney Australia
    It does come with a driver CD but you can download a free version of Techstream Software by just googling "miniVCI download". You probably will not find the latest version 7.30.
    I bought my miniVCI Xhorse from Ebay a couple of years ago when they were a bit more expensive and it still works fine. No complaint.
    See this shortcut Praise of the "MINI VCI" | PriusChat and
    Mini-VCI/Techstream works on Gen1 | PriusChat
  5. bobodaclown
    bobodaclown Member
    214
    71
    new MINI VCI FOR TOYOTA & Software TIS Techstream v7.20.037 Cable
    it was $23 bucks delivered.
  6. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Thanks for the info guys, I just placed a order for 26 bucks. Hopefully I will be able to get it to work with my car and laptop.
    Thanks again
  7. nai1ed
    nai1ed 2006 Prius
    52
    Maine
    I ordered version 8.00.034 with CD/Drivers for $25.99 on Ebay, and it worked great. It's a hacked version of Techstream but that's okay, was able to get codes that my OBDII wouldn't. Saved me $90 visit to the dealer, plus a whole lot of BS.
  8. Malcolm338
    Malcolm338 Junior Member
    27
    Carlisle uk
    will this work on windows 7 or has it to be xp as some one stated on a previous thread.
  9. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Works on Vista ok so should run on 7.
    John (Britprius)
  10. goitalone
    goitalone Member
    190
    16
    Port St. John, Florida
  11. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I got my mini vci v8.00 034 tech stream and am having problem getting it to work.
    Laptop running win xp, installed drive, software and key code. Now I get a box that wants me to register before my 30 chances run out, now I am down to 15.
    I tried to register but the link in the box does not work. Once I click ok on the box it connects using the USB but I don't see any thing on tech stream coming from the car while its running.
    I think I need some help here.
    Thanks
  12. goitalone
    goitalone Member
    190
    16
    Try uninstalling version 8 and download a version 7.xx.xxx of TechStream software.
  13. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi boppo,
    You need to edit the IT3System.ini in Program Files\Toyota Diagnostics\Techstream\Env
    Change TISFunction=1 to 0
    Do make sure you select your interface in Setup -> VIM Select.
    Vincent
    nh7o likes this.
  14. goitalone
    goitalone Member
    190
    16
    Do you if know if TS will work with Elm327?
  15. vincent1449p
    894
    331
    Singapore
    TS requires SAE J2534 compliance devices and ELM327 is not.
    Vincent
  16. goitalone
    goitalone Member
    190
    16
    I see, thanks!
  17. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Nailed told me to reinstall tech stream and that fixed all my problem. Now in the morning I will plug it in the car and see if it works in the car.
    That for all your help guys and will let u know how it goes.
  18. nai1ed
    nai1ed 2006 Prius
    52
    Maine
    Glad to hear you have it working now. It has saved me boat loads of money.
  19. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I plugged it in my cars and all is working as it should.
    Thanks for all your help.
  20. KiwiAl
    KiwiAl Junior Member
    146
    New Zealand
    Hi Vincent,
    Do you know of any devices that are suitable?
