Mini VCI/Techstream for Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by jerrymildred, Mar 16, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    If this has already been answered, I couldn't find it. Has anyone yet connected their mini vci and techstream to their Prime? I did that the other day to change the reverse noise to one beep. When it wanted me to choose the vehicle, nothing on the list was newer than 2015. I still got it done, but I imagine that continuing to use it might cause problems. Or at least fail to access all the codes and settings.
    Or, since I don't need it often, maybe Carista would fit the bill with less hassle.
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    This is the current list of Carista settings for my Prime.
    The following settings were available specifically to your vehicle using Carista:
    Doors / Windows / Remote
    Wireless door locking
    *ENABLED* / DISABLED
    Blink turn signals when locking/unlocking with remote
    *YES* / NO
    Beep when locking/unlocking with remote
    *YES* / NO
    Volume of beep when locking/unlocking with remote
    OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX
    Beep when opening/closing windows with remote
    *YES* / NO
    Allow locking when a door is still open
    *ON* / OFF
    Warn (beep) when door can't be locked because it's still open
    *YES* / NO
    Ding when key is left in the car
    Ding when key is out of the car and ignition is on
    *YES* / NO
    Warn (beep) when a window is still open when locking doors
    *YES* / NO
    Warn (beep) when sunroof is still open when locking doors
    *YES* / NO
    Panic function on remote
    Re-lock doors automatically if you unlock, but don't open a door
    *YES* / NO
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 SECONDS / *60 SECONDS* / 120 SECONDS
    Unlock doors via remote
    *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
    Unlock doors via physical key
    Unlock doors via smart key (door handle button)
    DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
    Max number of consecutive lock/unlock cycles via touch sensor
    UNLIMITED / *2 TIMES*
    Auto-lock all doors
    DISABLED / WHEN SHIFTING INTO GEAR / *WHEN VEHICLE STARTS MOVING*
    Auto-unlock all doors
    DISABLED / *WHEN SHIFTING INTO PARK (P)* / WHEN DRIVER'S DOOR IS OPENED
    Touch-to-unlock-doors minimum duration
    OFF / SHORT / *MEDIUM* / LONG
    After locking with smart key, don't allow re-opening within…
    0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
    Smart key location to start car
    FRONT SEATS / *ANYWHERE IN VEHICLE*
    Open trunk via smart access button
    DISABLED / DOUBLE CLICK / *LONG PRESS*
    Open windows and sunroof by turning and holding key in door lock
    ON / *OFF*
    Close windows and sunroof by turning and holding key in door lock
    ON / *OFF*
    Open windows and sunroof via long-press on remote
    ON / *OFF*
    Open driver's window using single button press
    *YES* / NO
    Close driver's window using single button press
    *YES* / NO
    Open passenger's window using single button press
    *YES* / NO
    Close passenger's window using single button press
    *YES* / NO
    Open rear left window using single button press
    *YES* / NO
    Rear-left window single-touch-close
    *YES* / NO
    Open rear right window using single button press
    *YES* / NO
    Rear-right window single-touch-close
    *YES* / NO
    Passenger window single-touch-open from driver's switch
    *YES* / NO
    Passenger window single-touch-close from driver's switch
    *YES* / NO
    Rear-left window single-touch-open from driver's switch
    *YES* / NO
    Rear-left window single-touch-close from driver's switch
    *YES* / NO
    Rear-right window single-touch-open from driver's switch
    *YES* / NO
    Rear-right window single-touch-close from driver's switch
    *YES* / NO
    Instruments / Display / Dings
    Engine start indicator
    *ON* / OFF
    Display odometer after ignition is turned off for…
    *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
    Reverse-gear beep
    *BEEP ONCE* / KEEP BEEPING WHILE IN REVERSE
    Seat belt warning ding (driver)
    Seat belt warning ding (front passenger)
    Seat belt warning ding (rear passengers)
    Turn signal click volume
    LOW / *MEDIUM* / HIGH
    Lane-change turn signal auto-flasher count
    OFF / *3 FLASHES* / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
    Remote low battery warning
    *ON* / OFF
    Front parking sensor range
    NARROW / *WIDE*
    Rear parking sensor range
    NARROW / *WIDE*
    Mute parking sensor when stationary for more than 3 sec.
    YES / *NO*
    Lower parking sensor beep volume when stationary for more than 3 sec.
    *DON'T CHANGE VOLUME* / 1 / 2 / 3
    Lower parking sensor beep volume when moving away from objects
    DON'T CHANGE VOLUME / *1* / 2 / 3
    Parking sensor beep volume
    1 / 2 / *3* / 4 / MAX
    Side parking sensor range
    SHORT / *LONG*
    Side parking sensor beep
    *YES* / NO
    Front side parking sensor range
    SHORT / *LONG*
    Rear corner parking sensor range
    SHORT / *LONG*
    Disable temporary muting of parking sensor above…
    AUTOMATIC / 15 KM/H / *20 KM/H* / 30 KM/H
    Display temporary parking sensor muting status
    *YES* / NO
    Activate parking sensors in neutral (N)
    YES / *NO*
    Vehicle Proximity Notification System beep volume
    *NORMAL* / HIGH / VERY HIGH
    Auto-turn off parking display when moving away from obstacles
    *YES* / NO
    "Master caution" light
    *ON* / OFF
    Lights
    Daytime running lights
    *ON* / OFF
    Coming-home lights duration
    OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
    Auto headlights activation threshold
    DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
    Instrument lights dimming sensitivity
    Instrument lights restoring sensitivity
    Dim interior lights after…
    7 SECONDS / *15 SECONDS* / 30 SECONDS
    Turn on interior lights when you shut off engine
    *YES* / NO
    Turn on interior lights when you unlock doors
    *YES* / NO
    Turn on interior lights when smart key in range
    *YES* / NO
    Interior footlight (bright when doors open, dim when driving)
    *YES* / NO
    Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
    *YES* / NO
    Interior light control
    Heater & A/C
    Ambient temperature calibration
    -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
    A/C ECO mode
    A/C compressor noise reduction
    ENABLED / *DISABLED*
    S-Flow function
    Open air flow to footwell when AUTO button pressed
    *YES* / NO
    Auto-increase blower speed when front defroster is on
    *YES* / NO
    Auto-turn on A/C when AUTO button pressed (if needed)
    *YES* / NO
    Open vents to outside air when ignition is turned off
    *YES* / NO
    Fan speed reaches its target…
    SLOWLY / *NORMALLY* / FAST
    Other
    Automatic wipers (using rain sensor)
    *YES* / NO
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    *FAR* / REMEMBER LAST DISTANCE
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    FAR / *REMEMBER LAST DISTANCE*
    Pre-Collision System (PCS) sensitivity: remember last state
    Stop monitoring for car key signal after…
    5.000000
    Obtained with Carista 3.7.5 for iOS.
    Download app: ‎Carista OBD2 on the App Store
    Facebook: ‫Carista - الصفحة الرئيسية | فيسبوك‬
    iPad
    Prius from Dad likes this.
  3. illumiN8i
    illumiN8i Active Member
    178
    139
    Grand Rapids, MI
    2018 Prius Prime
    What version of techstream? Mini vci cables typically come with an old pirated version. Carista is the best legal option.
  4. jerrymildred
    11,508
    14,109
    Tampa, FL
    Not sure without booting up the old laptop. It is pre-Prime, though.
    Thanks for such a complete listing, @schja01. I copied it into my notes for future reference.
    Still wondering who has used Techstream on a prime and what version.
