Mini VCI v10.30.29 won't sccess all ecu's
Discussion in 'Gen 2 Prius Technical Discussion' started by Backyardbill, Oct 9, 2016.
  1. Backyardbill
    Backyardbill Junior Member
    30
    2007 Prius, 178k, newly bought 2 weeks ago, runs great
    I ordered the mini-VCI cable and software, mainly to add another SKS key and check the hybrid battery status.
    Bought a used SKS FOB from ebay.
    Installed software (but 1st removed the virus tha came on the CD), plugged in OBDII cable, car in ign mode. scanned all ecu's. But only a few ECU's show non * asterisk status.
    Anyone know why Techstream won't access the other ECU's?
    Thanks in advance!
    PS: I love this little engineering marvel of a car!
  2. JC91006
    16,936
    8,647
    To make 1 key fob, you should've bought new. You're not going you save much money programming key yourself. You need to reseed the car and have to buy a code to do that. It's not free
    Fern1461 likes this.
  3. Backyardbill
    30
    Yeah, I found out that by reading you posts AFTER I bought the fob (bang head on wall). Do you know why the Techstream isn't reading all the ECU's? And where I can get another Techstream download without the embedded trojan virus(s)?
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Check the pins on your mini-VCI to make sure none are bent. Sometimes, the cheap cables are not made well (and the problem can be an internal connection), so you might need to get a replacement from your vendor.
  5. Backyardbill
    30
    The pins are straight. I'm requesting a refund from the eBay seller. Can you recommend a good quality source for this?
  6. Backyardbill
    30
    can anyone recommend a mini-vci with techstream that will access all the ecu's in a gen2 prius? And where to buy it. Feel free to email me. Thanks
    PS: I returned the one I bought that didn't access everything.
  7. ChapmanF
    19,008
    Is that necessary for Gen 2 keys also? I know it's true for Gen 3, but OP has a 2007.
    If you bought a used fob that hasn't been virginized, you may be able to have that done to the used fob you bought for not much money (and bit of hassle waiting for shipping, etc.). Then it's not necessary to reseed the car.
    -Chap
  8. ChapmanF
    19,008
    Probably a real Mini VCI would work well if you could get one, but as far as I know, the thing has been cloned so aggressively that the cheap clones drove the original maker (XHorse) right out of making them, so any Mini VCI you can buy anywhere is a clone (of some variable level of quality). Some of the clones reportedly work better than others, but it's hard to know which one you're getting (because they really are clones, right down to cloning the "Mini VCI" on the label).
    I also ended up with one that doesn't talk to all my ECUs. I have been meaning to try a Tactrix Openport (San Francisco company) to see if it is more reliable, but I haven't yet, so I can't report.
    Even with the Openport you have to be careful. It's real if you buy from their website, but you can also find what look like "way better prices" elsewhere, and of course those are, again, clones. I'm planning to buy a real one when I get around to it, because I don't want to contribute to driving them out of the business too....
    -Chap
  9. Backyardbill
    30
    Thanks for the tip on the virginizing . That looks good.The Tractrix website is down for maint. I check that out too.
    #9 Backyardbill, Oct 12, 2016
  10. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
  11. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Out of interest which file did your virus checker quarantine as containing a trojan?
    On the issue of interface cables, for a few dollars more (actually $60-$80) you can get a much better interface called VxDiag. Search for VxDiag for TIS on Amazing market place or fleabay.
    It is much easier to install, is more reliable and works faster, which you will appreciate if you spend any time using the MVCI clone.
  12. Backyardbill
    30
    Update. Apparently this
    "Virgin Toyota Lexus Scion Smart Key Unlock Reflash Reset Keyless FOB Prox"
    doesn't list the 2007 Prius in the compatibility list.
    The Tectrix website doesn't show KWP in the protocol list.
    So I'm still looking for a mini-VCI that will access all the ECU's in my 07 Prius.
  13. Backyardbill
    30
    I used AVG. It found the virus in 3 files.
    I just you post on the VxDiag. I will look into that one tonight.
  14. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
  15. dolj
    dolj Senior Member
    8,640
    4,391
    I was more interested to know the name of the particular file(s).
  16. Backyardbill
    30
    This was packed into the files on the techstream CD.
    jdcollins5 likes this.
  17. dolj
    dolj Senior Member
    8,640
    4,391
    That is actually only one file – FirmwareUpdateTool.exe. The other two point, a), to the directory path that contains the target file; and b), to the cabinet (compressed) file that contains the target file. These all point to the same file identified as containing the trojan.
    This is a file associated with the cable driver not Techstream. It is also not necessary to run this file to install the cable driver, so it is no loss. I also believe it is a false positive hit, but err on the side of caution and discard the file.
    Thanks for the feedback.
    #17 dolj, Oct 16, 2016
  18. b100
    b100 Member
    145
    75
    Netherlands
    I have the same problem here, Techstream can't access all the ECU's.
    Tried too install the software again, but didn't help.
    So maybe my Mini VCI is broken as well.
    I'm going to Pay and Pray another one...
    EDIT:
    Yes its fried
    #18 b100, Nov 27, 2016
