Minimum miles/month to keep ‘05 happy and healthy?
Discussion in 'Gen 2 Prius Main Forum' started by dmaxdmax, Jul 30, 2018.
  1. dmaxdmax
    dmaxdmax Junior Member
    43
    As discussed fairly recently, I have an ‘05 with 175k miles that I’d like to keep around for awhile though it will be demoted from being the primary to the secondary car. (5 years is a good target) How much or how often does it need to run to keep everything from getting auto-arthritis? It will do lots of short trips around town but I assume that it should also get some full speed highway time.
    Thank you.
  2. DMC-5180
    DMC-5180 Active Member
    292
    134
    You should try to drive it weekly. I know thats hard to do once you get used to driving your New primary driver.
    iPhone X ?
    49,490
    limited driving days may require a 12v maintainer.
    the bigger issue is the hybrid battery. does she burn any oil?
    srellim234 and Mendel Leisk like this.
  4. DMC-5180
    292
    134
    He said, 175k
    iPhone X ?
  5. dmaxdmax
    43
    No significant oil is burning. I’m reading threads on how to get an idea of battery life. If we replace I will absolutely plan on at least 5 years.
  6. dmaxdmax
    43
    She had a 1 year old 12v
  7. bisco
    49,490
    would still need a maintainer if only driven one or two days a week.
    srellim234 likes this.
  8. dmaxdmax
    43
    I had to google 12v maintainer!
    DLC82SV and bisco like this.
  9. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    If you're still on the original HV battery or a rebuilt, it won't last another 5 years or even 1 year with little to no use. See the link in my signature to see what happens. Budget accordingly.
  10. dmaxdmax
    43
    It will get used, just not as much as before. I’m thinking that I’ll use it until it needs a battery at which time I’ll assess the wisdom of putting >$2k into it.
    Reading your link now...
