MiniVIC . . . may have a problem
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Mar 27, 2013.
  1. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Have you uninstalled the previous 1.4.6 MVCI driver?
    Vincent
    Former Member 68813 likes this.
  2. Former Member 68813
    3,524
    983
    US
    Good point. I haven't.
  3. coobic
    coobic New Member
    Bob or friendly_jacek, i have the same issue (chineese cable with 1.4.1 firmware for NHW11) and cannot find cables with latest firmware.
    Can you send me links to cables which you buyed.
    Thanks for reply.
  4. bwilson4web
    16,533
  5. simplicity
    simplicity Junior Member
    Bob, did you order the mini vci or the XHorse cable from IMMOKM?
    I too ordered off Amazon but received a 1.4.1 cable. It fails the cable test on the CAN, L+K signals. I'm debating if I should return it and try my luck else where.
    What am I missing out on with a 1.4.1 cable and are all MVCI clones on 1.4.1? (ie. only XHorse is 2.0.1)?
    Thank you.
  6. bwilson4web
    16,533
    My first cable was also from Amazon and had the same 1.4.1 firmware problem. I tried to use the firmware update software but apparently Xhorse turned off the server. Then I found IMMOKM and learned they are an Xhorse reseller. Their miniVCI cables come in 2.0.1.
    Now my Amazon cable worked with our NHW11 but would not work with our 2010. About a year ago, I sent the 1.4.1 to the kid in the Pacific with the NHW11 under the Palm trees. I've never heard back but then I wasn't really expecting anything.
    Sorry,
  7. simplicity
    Thanks, I will see if I am able to return the cable to Amazon seller and order from IMMOKM.
  8. Prodarwin
    Prodarwin Junior Member
    30
    2002 Prius
  9. Patrick Wong
    18,210
    6,517
    I recently bought this mini VCI model on Amazon:
    Here is the vendor's actual website, which is also an alternate place to buy this:
    Toyota Mini VCI TIS Techstream J2534 OBD2 Diagnostic Scanner
    This will work with Windows 7, 32 bit OS without requiring any special tricks. However my McAfee antivirus SW reports that the MVCI32.dll file is a trojan. That file is needed to establish communication with the vehicle, so I have to take the file out of "quarantine" when using Techstream and turn off the McAfee file scanning capability, then put the file back into quarantine and turn McAfee back on, when not using that application.
    I am using a MacBook Pro with Boot Camp 4 and Windows 7 Home Premium, 32 bit OS. I tried using Windows 7 Home Premium 64 bit OS along with the hack described in the 4Runner forum, but found that the registry hack did not work for me. I had a problem similar to that described by the poster Simbot in the string below.
    (Solution) Mini VCI + Toyota TIS Techstream 8.x on Windows 7/8 64-bit. - Toyota 4Runner Forum - Largest 4Runner Forum
    I tested this on my 2006 HiHy and 2004 Prius. It automatically recognized both except that it thinks my 2004 is an 2005. That is easily corrected with the drop down menu.
    The cable check utility shows all lines to be green except number 5, the L line. So this result is better than that described in the 4Runner forum string.
  10. Patrick Wong
    18,210
    6,517
    Over the weekend, I sent an email to the customer service dept of the vendor who sold the mini VCI, to complain about the trojan file, but (not surprisingly) have not received a response. I am wondering whether other users of mini VCI can check to see whether they have MVCI32.dll installed on their computers. If you find this file, does your antivirus software have a problem with it?
    If your AV software believes your file is clean, I'd appreciate it if you could contact me via PM. I'd like to receive a clean copy of the software via email so that I don't have to worry about having a trojan file on my system. Thanks!
  11. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    There's a site I use which checks an uploaded file (max size 64MB) against about 40 antivirus databases, and shows the results from each one. This might help identify if the DLL file is really a Trojan.
    VirusTotal - Free Online Virus, Malware and URL Scanner
    Patrick Wong likes this.
  12. Patrick Wong
    18,210
    6,517
    Thank you. That site shows that 6 out of 45 antivirus databases believe that the "MVCI Driver for Toyota" file contains a Trojan. MVCI Driver for Toyota produces the MVCI32.dll file among others.
    I'm a bit unclear about the potential impact of this Trojan.
    AntivirusResultUpdate
    Ikarus Trojan.Win32.Spy 20130312
    Kingsoft VIRUS_UNKNOWN 20130311
    Norman Suspicious.D2!genr 20130312
    Panda Trj/Thed.A 20130312
    Symantec WS.Reputation.1 20130312
    TrendMicro-HouseCall TROJ_GEN.R47H1E2
    20130312
    NortTexSalv04Prius likes this.
  13. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I think some of the antivirus programs are ultra-conservative and flag as potential malware anything they don't recognize. For example, here's what Symantec says about their result:
    "WS.Reputation.1 is a detection for files that have a low reputation score based on analyzing data from Symantec’s community of users and therefore are likely to be security risks. Detections of this type are based on Symantec’s reputation-based security technology. Because this detection is based on a reputation score, it does not represent a specific class of threat like adware or spyware, but instead applies to all threat categories."
  14. Patrick Wong
    18,210
    6,517
    I submitted the actual MVCI32.dll file (which is a hidden file) and got these results. 10 out of 47 antivirus databases say that file is a virus including McAfee (which I already knew).
    In my computer, the hidden file is located at C:\Program Files\XHorse Electronics\MVCI Driver for TOYOTA TIS\
    Agnitum Suspicious!SA 20131020
    AntiVir TR/Crypt.XPACK.Gen 20131021
    Bkav W32.Cloda4a.Trojan.61e1 20131021
    Comodo MalCrypt.Indus! 20131021
    Ikarus Trojan.Win32.Turkojan 20131021
    Kingsoft Win32.Malware.Heur_Generic.B.(kcloud) 20130829
    McAfee Artemis!72EA5ACD1F5C 20131021
    McAfee-GW-Edition Heuristic.BehavesLike.Win32.Suspicious-BAY.G 20131021
    Norman Suspicious_Gen4.ESSAQ 20131021
    Panda Trj/Thed.A
    20131021
  15. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I'm definitely not an expert on malware (pretty good on Unix/Linux systems, though), but those "generic" and "suspicious" results really mean "we have no idea what this is". And "heuristic" just means "stuff that looks somewhat like this has sometimes been malware".
    If you haven't seen any ill effects from periodically taking the DLL file out of quarantine, it's most likely safe. But old PCs are cheap, and what I do is keep one with no connection to my network or the internet just for running suspicious programs. I have an antivirus program on it which lets me execute programs step by step, with approval required at each step so I can see what it's doing. And if the machine gets infected I can just wipe it and start over with a clean install of Windows.
    For the mini VCI software an old XP laptop would be ideal.
  16. vincent1449p
    894
    332
    Singapore
    Hi Patrick,
    I've checked my older driver against virustotal.com today, it says this file was first analysed by VirusTotal on 2011-09-27 03:46:58 UTC and it found 6/47. Someone must have submitted this file before as this is the 1st time I'm checking. I did a reanalyse and it found 3/47.
    Antiy-AVL Trojan/Win32.TGeneric 20140308
    K7AntiVirus Trojan ( 0034218c1 ) 20140307
    Norman Suspicious.D2!genr 20140307
    I looked at your analysis report and all the dates are 20130211~12 so it is not the latest scan using the latest updates. Please do a reanalysis to see if any difference.
    Vincent
  17. Patrick Wong
    18,210
    6,517
    Hi Vincent,
    Well, whether the results are 3 out of 47, or 10 out of 47 - it bothers me that any of the AV SW packages think that a trojan is in the file. Since I use McAfee, and that SW definitely thinks that MVCI32.dll has a trojan, I feel it is appropriate to keep the laptop disconnected from the Internet when I am using Techstream and have McAfee file scanning deactivated.
    ftl likes this.
  18. vincent1449p
    894
    332
    Singapore
    Hi Patrick,
    I'm not saying you shouldn't be bothered. My point is that all AV SW have their limitations. They depend on certain code patterns to judge whether it is virus-like or malware. That is why they need to keep updating their virus pattern files.
    For my e.g., the 6 suspicious viruses are same as yours but left only Norman still thinks it is a virus after updates. Even if the list shows 0 virus, I would not say it is virus-free. The best practice is to use a standalone laptop that does not have internet connection, WiFi, BT and external storage like thumbdrives or USB HDD. Temporary deactivating AV to use Techstream is still not safe.
    Vincent
  19. bwilson4web
    16,533
    I've come to the conclusion that windows is such a virus lint-collector, it isn't clear that anything can be done about it. But I thought at one time, there were virus removal tools that could extract the offending code. Is that no longer the case?
    The last virus I had to deal with came with a recording ECG/EKG system, a Holter monitor. In my case, the detected virus was in the 12-channel software, not the 5-channel I was using. So I deleted the offending file and it scans clean BUT I do not trust it.
    I too use Macintosh with Virtual PC. So PC software goes on a virgin 'image' that has previously been updated with the latest Microsoft patches and virus profiles. But I have low expectations about the virus detection software as the virus authors have the initiative and 'defense' has to respond to the new pattern. It is worse at work.
    Windows PCs is the corporate standard and there is a contractor, ACES, whose job is to provide the hardware and software. My work PC has not gone more than two weeks without being rebooted at will by the contractor ACES. They do not care what we are doing at the time so randomly a message pops up "Going down for reboot" and I get up, walk around the building, and come back when I'm calm to start the 10 minute, multi-stage, login. My favorite joke around the shop in my 'calm down' walks:
    • "ACES has made me appreciate the reliability of Windows 95."
    Since 1985 when I bought my first Mac, I have been amazed at the labor overhead of DOS/Windows PC versus Macintosh. The support labor for a PC varies but is roughly 2-3x higher than an Apple and that was reflected in the size of the relative support staffs. But with support staffs comes labor budgets and . . . supervisors. Pay me now or pay me forever . . . much like Prius people who pay a little more at the beginning so we don't want to pay at the pump year after year after year.
    I appreciate your efforts to map the problems of the hacked, miniVCI. If I were committed to getting something working, I would have bought a USB debugger and reverse engineered the OBD commands from miniVCI and hosted them to an open source package. In effect, being able to publish something like the ScanGauge XGAUGEs. But I'm not that committed in part because I have enough historical data to not have the curiosity needed to do that effort. Granted most of my knowledge dates from our NHW11 but I'm not seeing enough 'new' and I have another hobby to take my time and budget.
    So I appreciate the work you' all are doing but have to remain on the sidelines . . . offering encouragement but I personally don't have enough motivation to 'pickup the tools.'
    GOOD LUCK!
  20. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I looked at the x horse cable recently and it seemed to work great. It could even program gen 3 keys. It did not appear to work on gen 1 but it looked like it was working well on gen 2. I think it talked to the engine computers of both gen 2 and 3.
