Minor Crash Causes Devastating Fire?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ecowan, Jul 10, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    An uncle of mine had a 1968 Ford Fairlane 500 that he ordered with a 390 V8. That thing had no problem melting the rear tires
  2. dogfriend
    7,512
    1,191
    Carmichael, CA
    I would like to see a photo of the Prius.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    My first thought was that the battery is wayyyy in the back but the impact was wayyyy in the front. I can not imagine how the battery itself could be responsible. Once you turned the power off, there should be no power running through the bright orange cables. However, if there was damage to the system that somehow disabled your ability to fully shut down the car then maybe leaking fuel hit a bare wire. I know that you mentioned that the impact was up and away from the tank but, as was mentioned, the fuel lines run up the right side of the car. so perhaps a severed fuel line leaked gasoline onto exposed wires. Or perhaps onto hot metal.
    As for the emergency response manual. I carry a copy in my glove box.
    And in case you missed the part about the airbags, the Prius physically severs the power connections to the hybrid battery upon airbag deployment. This is a safety feature. So the fact that the airbags did not deploy eliminates that.
    I'm glad to hear that you are okay. I hope the gun shy members haven't scared you away. And since no one has said it yet, welcome to PriusChat. :welcome:
  4. ecowan
    ecowan New Member
    Vermont
    I do have photos for the purpose of insurance, but not on my own camera, so I'm waiting for a family friend who happened to drive by shortly after the accident to e-mail them. I will post them here as soon as they arrive.
  5. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    I'm actually stunned that the airbags did not deploy when the car rolled over... I thought that was automatic with all Toyota products. I'm going to have to look into this one..
  6. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    Consider this: In a typical car the engine would have been MUCH hotter and caught fire before you got out. Thank goodness the Prius runs cooler BECAUSE of the battery assistance and delayed the fire!!!:D
  7. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    See pages 117 -119 of the manual. The front air bags are set to deploy if the impact with an object (tree) exceeds a threshold level equivalent to 12-18mph. They don't inflate with a side, rear or rollover. 'Sufficient forward deceleration' is what triggers the front air bags. It's sort of ditto for the side curtains.
  8. timberwolf
    timberwolf New Member
    220
    31
    UK
    Does the following description from Ecowan really mean a roll-over though? To me a roll-over means rotating the car at least 180 degrees onto the roof. This description sounds more like one side of the car slide a litte way up the trunk of the tree?
  9. Jabber
    703
    215
    Chicago
    I was under the impression that anytime the car/truck/suv goes more than about 65 degrees, the system assumes an imminent roll over. Whether it goes on the roof is irrelevant at that point. Some trucks even come with a button that disables the roll over point for extreme off roading.
  10. timberwolf
    220
    31
    UK
    Okay, so 65 degrees for an imminent rollover. Thinking about I am going to revise my definition of rollover to mean anything greater than 90 degrees.
    PS Did the tree survive?
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    With a car laying on its side or upside down, how about all that windshield washer methanol and engine oil running out all over the hot motor?
  12. ecowan
    ecowan New Member
    Vermont
    Here are photos from my dad after the car was towed, I'm still waiting on the ones from the actual scene of the accident.
    Pictures by ecowan37 - Photobucket
    The car hit the tree from the right front side (on the wheel well), and pushed the car up on it's side. From there it slowly tipped down to rest on the road on it's right side.
  13. ecowan
    ecowan New Member
    Vermont
    As you can see, the air bags did deploy once the fire started and after I was already out of the car.
  14. patsparks
    10,664
    569
    Adelaide South Australia
    Most car fires are caused by short circuits in the 12 volt electrics.
  15. Patrick Wong
    18,210
    6,517
    Wow, thanks for providing the photos. Glad that you were not seriously hurt and that you got out of the vehicle as quickly as you could.
    The airbags would not deploy upon impact since you hit the tree with the RF fender and not with the front bumper where the sensors reside.
    Do you remember whether you had turned off the car after the accident? If the car was still READY, the fuel pump would continue to run and if a fuel line had broken and fuel contacted the exhaust manifold or other hot component, this would allow a fire to start.
  16. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Interestingly the shoe seems standing up to the fire pretty well.
  17. 2009Prius
    2,705
    512
    63
    Have you figured out how exactly the car went off the road and ran into a tree? This can be a good learning opportunity for everyone. Did your right hand unintentionally turned the steering wheel while your left hand was swatting the bug?
  18. dogfriend
    7,512
    1,191
    Carmichael, CA
    Special Nomex and concrete construction.
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Do you think this one will be rebuilt and sold as salvage: "New upholstery!" :D
    Sorry about your car, but happy that everyone got out okay.
    Tom
  20. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Why is this assumed in the first place to be a battery fire. It is probably more a fuel fire.
