Featured Mirai In Florida
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Hicksite, Feb 17, 2022.
  1. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I was on subs too.
    Mike
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Hicksite and Trollbait like this.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    PS- You are right 10000-psig is high ....4000 is my max personal experience.
  4. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You all do know that there are impurities in the air used to react with the hydrogen that can also "poison" the catalytic stack.
    JeffD
    bwilson4web likes this.
  5. bwilson4web
    16,554
    I knew that but was too polite to cite the obvious. Worse, it might suggest I have/had any interest in the technology, But it begs the question if 'coal rolling' is a risk ... batteries are immune.
    hill likes this.
  6. Trollbait
    12,836
    Are typical gas cylinders below that?
    There's a difference between a trace amount in the air from ICE cars, and the fuel hydrogen itself being laced with it. A carbon filter on the air intake would probably capture much of the air contaminates.
    PEM fuel cells in cars have a short life. They might good 90k miles with an average voltage drop. Poisoning likely plays a part. They'd likely degrade faster with dirtier hydrogen.
  7. hill
    9,046
    "Typical" gas cylinders is an amorphic term. For diving purposes at work & for sport - I broke up a set of cylinders used for scuba referred to as "twin 38's". Small & convenient for crawling through tight spaces underwater at Disney - as well as having a decent amount of time underwater. Each was only rated at Max of 1,800 PSI. We've come a long way since the 1960's tank cylinder tech. As substances like carbon fiber & the strength of alloys continue to increase, as well as compressors ability to compress ... who knows how ridiculous High pressures may get. Kind of makes one want to cringe. And if those pressures are in a car? No thanks.
  8. Trollbait
    12,836
    I was referring to the ones seen in a lab or industrial setting. They still use steel for those.
    hill likes this.
  9. Gokhan
    Gokhan Senior Member
    6,722
    2,672
    Paramount CA
    We have a lot of Mirais in the LA area. Before the supply-chain issues, a single dealer had about 80 of them in stock. Currently, there are only 32 in stock in the LA area, which is still many more than the Prius Prime.
  10. Trollbait
    12,836
    That isn't a good sign in today's car market.
  11. Gokhan
    6,722
    2,672
    Paramount CA
    The only Toyota for which there is a shortage is the Prius Prime, and that's because of the high gasoline prices. You can find any other model easily. For example, there are 224 gas-guzzler new 2022 Tacomas in the LA area.
    Toyota inventory | new-Toyota inventory search
  12. Trollbait
    12,836
    With 3 years or $15k in in fuel and large incentives, shouldn't the Mirai be moving better?
    There is only 20 Tacomas available in the northeast Philly area.
  13. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Number of hydrogen refilling stations in CA?
    Number of hydrogen refilling stations in FL? 0?
  14. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    50 public, with 9 under construction and 64 more funded. The 50 have been unreliable.
    2 in the orlando area but I believe these are private.
  15. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Thanks, yeah I would have overestimated for CA and underestimated for FL.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    2000 psig if I recall correctly getting rusty here
    Trollbait likes this.
  17. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,731
    Somewhere in Wisconsin
    2013 Chevy Volt
  18. ETC(SS)
    7,585
    ...a 1969 pontiac Firebird?
    Rmay635703 likes this.
  19. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
  20. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That will make it run, but you need to deal with the new battery being compatible with the regenerative braking.
    JeffD
