MISC questions about the Plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mrpcar, May 1, 2014.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    What's the charging priority? Charge up the plug-in battery first and then the standard traction battery? Or both charges at the same time?
    What's the best way to utilize the EV/HV mode? When to switch?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    There is only one battery pack, separated logically.
    EV: 85-23%
    HV: 23-20%
    Switching between EV and HV depends on the route (distance/speed/slope/recharge opportunity/etc). What is your typical commute like?
  3. Mrpcar
    542
    253
    Chino Hills, CA
    Typical commute 19 miles one way. 1st few miles down grade and then normal local city street, and then highway with partial 20 mph traffic. So unless it's cold I usually just run EV from the start and then switch to HV when I hit the highway. And then EV again when stuck in traffic. By the time I get to work I have about 5 miles left on the EV battery. After lunch it's all gone. Averaging only about 49 mpg right now, but I do have a lead foot, average speed on the freeway is 75-85 mph.
  4. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    With that same lead foot, what were you averaging in your 2013 Prius 3?
    EDIT: wait, let me guess.. 41MPG? :ROFLMAO: sorry, missed your sig
  5. Mrpcar
    542
    253
    Chino Hills, CA
    40 mpg
    Tracksyde likes this.
  6. Mrpcar
    542
    253
    Chino Hills, CA
    I should have mentioned, the plug in purchased in April currently have... 17" TRD plus wheels, sway bar, TRD lowering springs, strut tower brace, under brace, HID headlight, LED parking light, LED interior lights, tinted windows, shark fin, clear bra, leather seat cover next. Pretty much all the same upgrade as the 2013 Prius 3.
  7. CharlesH
    2,798
    1,166
    Roseville, CA
    As mentioned in another reply, there is only one big battery (plus the 12V auxiliary battery). The software manages it either in hybrid vehicle (HV) mode (like a regular Prius) or Electric Vehicle (EV) mode, depending mainly on its state of charge. The Plug-in prototype had two physical batteries, and sometimes people stumble across old web pages referring to them, and get confused.
  8. Valencia Orange
    192
    Valencia, CA
    2013 Prius Plug-in
    75- 85 mph on the freeway is to fast. You can cause danger to other drivers. Slow down.
  9. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    In Southern California (ok, more like Orange County), NOT driving 75-85 on the freeway is a danger to other drivers (i.e. you are an obstruction)
    Mrpcar, rxlawdude and DLee like this.
  10. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    Quite new to the PiP. I've been using my ~12.9 mi of EV for the first and last parts of the trip at low speeds, and when stuck in traffic. I try to use up all but .1 EV mi to destination which has a Chargepoint. Not a pro, not a road obstruction and not a hyper-miler. I've seen nearly 79 MPG displayed for a 42 mile trip - which is more than 25% higher than the expected 50 MPG, so I guess I'm doing OK.
  11. markabele
    5,084
    1,782
    Nebraska
    Why do you aim to leave .1 EV mi when you get to your Chargepoint destination?
  12. bisco
    52,658
    i think you're doing excellent!(y)
  13. bisco
    52,658
    good question, if my ice has already been running, i try to use up as much of the hv battery as possible before reaching my charging destination.;)
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I'm guessing that the poster likes to roll into town and the Chargepoint station without the ICE running one last time.
    I used to do that occasionally...
    srl99 likes this.
  15. markabele
    5,084
    1,782
    Nebraska
    If the ICE is warm it shouldn't turn on.
  16. Bill Norton
    Bill Norton Senior Member
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    It's only one smallish air-cooled Li-Ion battery pack, on the current PiP.
    The separation is an illusion.
  17. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    You never miss an opportunity to belittle and downplay. It says a lot about how much competition Prius actually poses. Keep the endorsements coming...
  18. markabele
    5,084
    1,782
    Nebraska
    My vote would be to ban the guy. He does not contribute anything to this forum, only negativity.
    He clearly feels self conscious about his car, otherwise he wouldn't be here. I feel no need to go to the Volt forum and belittle their car.
  19. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    "Just the facts, ma'am".
    It's not two batteries, correct?
    Just answering the OP, trying to help?
    Smallish is fine if you only need 6-12 miles, or whatever the current spec is, and don't mind the effects of hot climates.
    How is this offensive?
  20. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    That doesn't make it right. Just because everyone drives 20 miles over the speed limit just means the CHP are not doing their jobs.
    finman and Mendel Leisk like this.
