Misfire and valve cover gasket fix
Discussion in 'Gen 2 Prius Main Forum' started by sambojoho, Jan 2, 2018.
  1. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    I have a 06 with 245k miles. I did the most extensive engine repair ever completed on this car over the weekend and thought I would share my experience.
    The engine started running rough last week, and got a lot worse quickly. Was getting trouble codes P0300, P301, P303, and P304. All misfire codes (300 is random misfire, 30x codes correspond to their respective cylinder numbers. Started with the simple stuff, cleaned the MAF and throttle body (stab in the dark). Then pulled the coils and plugs. #1 looked fine, no issues. #2 had a small amount of oil on the plug, coil end only. Coil was clean, and firing side of the plug looked normal for a plug that's been in 50k miles. #3 plug had even more oil on the coil side, none on the firing side again. Electrode was worn pretty good on this one (I use NGK laser iridium every 100k miles).
    #4 was where things got really messy. Heavily oil soaked coil, and oil dripping from the upper portion of the plug. Firing side looked good though, little wear. Best I could tell from the condition, I had a valve cover gasket leak at the spark plug well connections.
    Repair went fairly smooth overall. Removed the air filter box, unbolted and moved the engine wiring harnesses, removed the coils, removed wiper blades, linkages, motor, and tray. I had to unbolt the brake fluid reservoir and move it out of the way, but did not have to disconnect any hoses thankfully. All the valve cover bolts/nuts were 10mm, about 10 of them I think.
    I have never done a valve cover gasket before, I was surprised to find it VERY fragile. Parts of it fractured like glass when I went to remove it. I was careful to collect any broken pieces. New one went on fine, after cleaning the surfaces with carb cleaner and a rag. Used black RTV sealant on the timing cover joint/seams and let it cure. Also used the new center bolt rubber gaskets that came with the gasket kit.
    Overall, probably took about 3 to 4 hours or so, but I was going slow and taking my time. In addition to the gasket, also replaced the PCV valve, all 4 spark plugs, and the #4 coil that was probably the source of the misfire in the first place. Engine runs smoother than ever now. Verified that there are no leaks. I pulled all 4 coils out after the test run-in and verified no oil in the spark plug wells also.
    A couple of questions for any mechanics on here, do you have a good suggestion for how to get the residual oil cleaned out of the spark plug well? I mopped it up the best I could, but there was still some varnish residue in there that wouldn't come out too well. Also, when I went to pull the plugs out, #4 plug was very loose in the engine. Really only finger tight. Why would that be? When I replaced them at 200k, I torqued everything per spec, so was really surprised to find it loose. Could it have simply rattled loose from the vibrations of the misfire??
    Jamie Fugitt and Mendel Leisk like this.
  2. DMC-5180
    DMC-5180 Active Member
    294
    134
    For washing oily residue off I prefer to use a spray can of starting fluid. It washes oil instantly and flash dries almost as fast. Stinks like crazy but extremely effective. You need the can that has the red straw with it. Since the coils seal the plug wells you don’t have to worry about extra crap getting in the wells other than the seeping oil. I would remove the spark plugs and just spray down into the wells. The fluid and oil residue will just wash into the plug holes. Don’t get to crazy with it. Just short blasts then inspect with a light. Repeat until satisfactory. Leave the plugs out for 5 minutes to let the starting fluid flash off. Then install them. By the time you get the rest of the components reinstalled for starting, you will be fine.
    Whatever oil or minor debris particles that wash into the cylinders will get burned and blown out the exhaust.
    I don’t like using brake cleaner for this kind of thing even though it is a quick drying solvent.
    I think the contribution of oil and mis-fire vibrations were likely the cause of the plug loosening.
    iPhone X ?
  3. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    I’d just use brake clean but other than that I’d do the exact same thing. Also clean the coil boots that had any oil on them carefully and inspect them.
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Did you at that point inspect or service the fuel injectors too? That would have being a better time to do that.
  5. Rocinante1984
    Rocinante1984 Junior Member
    Moscow, ID
    Wow I had no idea this repair was so easy. I must have taken all that stuff off a dozen times now when fixing my exhaust and fiddling with various things.
  6. Mendel Leisk
    42,373
    I once hacksawed the threads off an old plug (was on a bike), epoxy glued them to a slim dowel. Reach that down and screw into the spark plug socket, then you can spray and blow without washing stuff into the cylinder.
    Old Wrench It likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Why didn't you just put the spark plug back in?
  8. Mendel Leisk
    42,373
    Spark plug is much bulkier than a thin dowel, blocks the spray or air blast, tends to trap anything that is kicked up.
  9. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I just blow it out with the plug in. Then pull the plug and push a cloth towel soaked in carb cleaner down the bore turn it.. Squeaky clean.
    Really easy with the valve cover off. No depth.
