Misfire codes problem found
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamon, Dec 17, 2017.
  1. Jamon
    Jamon New Member
    Nebraska
    Thanks to this forum within 15 min with a wrench I have found out why I have severe knock, and multiple misfire codes. Look at that gunk in the EGR pipe....guess I'm spending the next few hours pulling the whole EGR system and cleaning.
    danlatu, RMB, Danny3xd and 3 others like this.
  2. Jamon
    Jamon New Member
    Nebraska
    By the way, how the hell is this not under recall. Seems like a failed system, and every Prius seems to encounter this crap.
    CR94 likes this.
  3. Dxta
    Dxta Senior Member
    1,943
    769
    Lagos
    Its just carbon buildup, and might not necessarily be on the recalled list
    makbg1 likes this.
    52,785
    welcome!
    oy, another 2010. how many miles on her?
    CR94 likes this.
  5. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    If Toyota does not consider it a failure, then it should be listed in the maintenance schedule.
    makbg1 and Grit like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks for posting and informing us.
    Danny3xd likes this.
  7. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    Yes, thank you!
  8. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    You mean like the brake flush and Trans fluid change they don't list either? I'm still waiting for someone to come up with an EGR Delete Mod (including the software delete) like with Diesels.
    SFO likes this.
  9. makbg1
    makbg1 Junior Member
    35
    LA
    my guess is that will be temp resolution. I had a knocking engine few months back and EGR was the first thing that was a cleaned. I had a misfire on cyl 1&2 coused by coolant leak at 175k ml. and after EGR spark plugs repl. and ignition coil. At the end I just replaced the engine with a 40k ml. one.
  10. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Kinda, but failure to perform those doesn't seem as consistently fatal. They're incidentally a lot easier.
  11. frodoz737
    4,795
    2,560
    33
    Consistently Fatal? Have not hear of one Prius that died because of a clogged EGR system.
  12. Danny3xd
    238
    149
    CT. U.S.
    How'd it go Jamon?
    Too cold to rip out and asking here.
    I never buy new cars. After buying a used car, I like to at least twice, while entering hwy traffic. I press the accelerator to the floor and all but red line it.
    Perhaps in the mistaken notion that it helps blow out carbon build up.
    Doubt it's as productive with high-tech engines as it was with older styles. Really, unscientificly seems quicker and peppier.
  13. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    If it supposedly causes knocking and high temperatures that knock out the head gasket, and fixing that costs more than replacing the engine, then the clogging was economically fatal to the engine. Maybe not to the car, depending on its value.
    Raytheeagle likes this.
  14. frodoz737
    4,795
    2,560
    33
    There's a reason why "Fix it before it breaks" is in my signature. :)
  15. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Did cleaning the pipe and valve fix your startup knock?
  16. bisco
    52,785
  17. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Also known as the italian tune up!
