Misfire Cylinder 4
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gjkristi, Dec 16, 2025.
  1. gjkristi
    gjkristi Junior Member
    39
    The plugs are from a retail store not Ebay or Amazon. If it were a bad plug you would think a cylinder swap would move the issue.
  2. ASRDogman
    ASRDogman Senior Member
    7,882
    4,012
    :oops::oops::oops::oops::oops::eek::eek::eek::eek:(n)(n)(n)(n)(n)
    I don't understand why you don't listen......
    Spark plugs go bad, some were where when they were made.
    The ngk plugs took over 1000 miles before going bad.. They were new, from autozone...
    Even if you have bought them from Toyota, one or more could still go bad...
    You had the coils out. It's only one more step to swop the SPARK PLUGS.....
    Why do you not want to swop them? Are they stripped out and you don't want to mess with them???
    Other than the head gasket leaking, and the wiring you said you checked, the plug is the last thing....
    You are more than welcome to just keep dragging it out though.....
  3. BiomedO1
    BiomedO1 Senior Member
    4,303
    2,258
    Left Coast
    Get another gauge and retest. Low compression would cause intermittent misfire. As the engine heats up; ignition in each cylinder becomes easier, because of all the heat generated. It's like having a roaring camp fire, where you just toss wood in vs trying to start a camp fire with wet wood. If it is in fact low, next step is to determine where it's leaking; past valves, rings, or head gasket. Bore-scope the cylinder walls to determine ring leak, pressurize the cylinder and listen to intake and exhaust manifold for leaks with a stethoscope. A more comprehensive test would be to disconnect the intake and exhaust manifold and inject smoke into the cylinder to see if anything rolls out of either manifolds. If the cylinder was totally dead, no compression - you may be able to see the burnt valve with a bore-scope.
    #23 BiomedO1, Dec 22, 2025
  4. gjkristi
    39
    Swapped injector 3 and 4 and now have miss fires on 3 . Looks like injector is the issue.
    BiomedO1 likes this.
  5. BiomedO1
    4,303
    2,258
    Left Coast
    I would suggest that you replace all 4, so you get an even distribution. Disconnect your battery to force an ECU relearn or force one through techstream.
    Good Luck...
  6. gjkristi
    39
    Thanks I will do a relearn through techstream
  7. gjkristi
    39
    Update: replaced the fuel injector and no more miss fires. Thanks to all that helped out on this issue.
    Brian1954 and bisco like this.
  8. bisco
    52,475
    congrats!
