Misfire on cold starts
Discussion in 'Gen 3 Prius Technical Discussion' started by Rob_Prius, May 28, 2018.
  1. Rob_Prius
    Rob_Prius New Member
    Hi there!
    I’m a 2010 Prius owner... and have loved almost every mile I’ve put on this car. I’m near the 200k mark at this point. I’m now starting to have some issues, when my car has been trouble free it’s entire life. On cold starts, I’m now getting a misfire on cylinder one. Thus far, I’ve changed plug, coils, clean my TB, and my EGR is pretty new. Any other areas, I should be looking at, in an effort to resolve this? I did buy new injectors, which I plan on trying next.
    Thoughts?
    Thank you!
    Rob
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I would read about the oil catch can, EGR system cleaning and head gaskets in the Gen 3 maintenance section of the forum. The engine has an ugly flaw that produces head gasket problems. IMHO it's preventable to some degree with the aforementioned steps.
    Pixel XL ?
    #2 mjoo, May 29, 2018
  3. Leadfoot J. McCoalroller
    8,280
    7,791
    Pennsylvania
    2018 Prius c
    Have you looked for a vac leak? Maybe flow a little cold propane near the intake flange and injector seal and see if the misfire momentarily goes away.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    Some vacuum leaks only happen with a cold engine and actually go away with the expansion of the engine as it watts up.
    You could do a cylinder leak down test to verify cylinder integrity.
  5. Blurredforlife
    Blurredforlife Junior Member
    75
    Chicago
    The dealership downloaded an update that seems to have solved this problem for me
  6. Radiospank
    Radiospank Member
    169
    82
    is there a way to see which updates you have?
