Misfire on cylinder 1
Discussion in 'Gen 3 Prius Main Forum' started by Dmmfox15, Jul 29, 2019.
  1. Dmmfox15
    Dmmfox15 Junior Member
    Temple Tx
    ok so a while back out 2010 Prius started running rough. We replaced the egr valve and cooler, the sensors and the plugs and coils it is running much better but we still have a intermittent issue and the code reader says misfire on cylinder 1 anyone have suggestions on how to resolve this?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How many miles on your Prius?
    • Is the engine coolant level stable?
    • Did you clean the intake manifold when the egr cooler and valve were replaced?
    Good luck and keep us posted (y).
    Mendel Leisk and CR94 like this.
  3. Dmmfox15
    Temple Tx
    There are 224000 miles on the car yes the intake Mansfield was cleaned at this time
    Raytheeagle likes this.
    52,742
    have you done a compression check?
    how much oil does it burn?
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    There are many, many reason why a misfire can occur. This is especially true in your case with your car having this very high mileage on the clock. A comprehensive diagnosis is the only true way to uncover the problem. Unfortunately, there are very few shops that you can trust to do this without paying a huge chunk of money. Your problem is probably going to be finding a good honest shop. Star by looking around for a reputable repair facility that has good customer feedback.
  6. Austin Longenecker
    124
    66
    Austin Tx
    I'd consider doing an engine coolant flush & replace even if the coolant is steady. Mine was steady, just a little low, so I changed it when I had similar issues to you, and like you, after having the EGR cleaned or replaced. The coolant flush completely eliminated the misfiring 100%. Its never returned since.
    MikeV likes this.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    That makes zero sense. How does a coolant replacement fix a misfire?
    mikey_t and Raytheeagle like this.
  8. bisco
    52,742
    old coolant = bad karma?
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Old coolant = pH imbalance
    pH imbalance = less protection
    Less protection = potential problems
    Mendel Leisk and bisco like this.
  10. Dmmfox15
    Temple Tx
    No we have not done a compression check
    and before all this it burned some oil but I understand that was an issue with this year prius
  11. bisco
    52,742
    not all of them, but some number typically start burning around 100k when the egr system clogs
  12. CR94
    CR94 Senior Member
    2,813
    1,235
    Northwestern S.C.
    Which is first? I'd guess it's more likely that burning contributes to clogging than vice versa. Or are those independent maladies?
  13. bisco
    52,742
    i don't think there's any consensus among the experts. your guess is as good as anyones. we'll probably know more as the 14's and 15's get up there, with the improved rings and pistons.
    mikey_t likes this.
  14. Austin Longenecker
    124
    66
    Austin Tx
    Honestly, I'm not entirely sure, but it immediately fixed the problem. Not to say correlation is causation, but all the arrows say that that's what fixed my misfiring.
  15. The Critic
    3,193
    2,333
    CA
    When the coolant flush was performed, did someone add type of "cooling system conditioner" or "cooling system stop-leak" as part of the coolant flush service?
    If they added an additive of that type, it would explain why your misfires stopped (assuming you had/have a leaking HG issue).
  16. Austin Longenecker
    124
    66
    Austin Tx
    Nope, I flushed it myself and did nothing other than remove the old fluid and refill it with new fluid. It worked so that's all I cared about.
    The Critic likes this.
  17. ifty1989
    ifty1989 Junior Member
    england
    2014 Prius c
    Excel
    I had the same problem. But I was getting a misfire on cylinder 3. Turned out to be the inlet manifold blocked on number 3. Cleaned it out and havnet had a problem since.
    Greenteapri and Raytheeagle like this.
  18. Mendel Leisk
    42,223
    At what miles was that work done? Maybe it's closing the barn door after the horses have already bolted: if you wait on cleaning the EGR system till the car's running rough, the engine's been running at elevated temperature for a long time: a easy-flowing EGR is instrumental in keeping combustion chamber temperatures down.
    mjoo, mikey_t and Raytheeagle like this.
  19. RacerNate
    RacerNate Junior Member
    West of most
    Hey first post!
    Toyota has a service Modification for this issue.
    First the wires running to the EGR need to be untapped from the main loom.
    NOT THE WHOLE WAY, just where they pulled them backwards.
    Then rewrap the main loom and the EGR wires separated.
    Hope this helps
  20. voxbox
    voxbox Junior Member
    Bozeman, MT
    Hey RacerNate, I have a similar issue, can you send me the number of the service bulletin so that I could look it up? I took it to Toyota today but they could not figure out what's wrong (attached) mine has 127k miles.
