Misfiring or something else?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bens04Prius, May 17, 2017.
  1. Bens04Prius
    Bens04Prius Junior Member
    New Jersey
    I Just cleaned the MAF sensor - the problem wasn't solved. I didn't get any codes related to the MAF sensor so this was more a shot in the dark.
  2. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I didn't say the new ones needed to be replaced.
    You asked Patrick if he could assist in reading the conditions of the plugs.
    You can't read the conditions, with the way you've positioned them facing down.
    If you want answers to that, take a picture of the tips of the plugs facing you. Its simple!
    Plugs have heat ranges. If they exceed em, you'd ha e issues. So, what I'm saying is, as part of reading those plugs, the ceramic insulation (white part), is severely brown/black, from heavy usage(if you understand what I mean); and that's y you did replaced them.
    PS: Plugs also helps to remove tremendous heat from the combustion chamber, via the top cylinder head, then the radiator cooling system, where its cool down.
    Dxta
  3. Bens04Prius
    New Jersey
    So I let the car idle for like 40 minutes after a 25 minute trip yesterday, and while it was idling (i put the heat to max so it would keep the engine on) it was running pretty smoothly. This morning car was definitely running better, no CEL but pulling codes shows pending cylinder 3 misfire code. Not sure why this helped - unless it has to do with adjusting existing MAF learned settings so extra on time helps with that. Maybe I will disconnect 12v battery to help reset that. Regardless, I'm seeing cyl 3 code more than anything else & cyl 1 is #2 in frequency. When its really bad, cyl 2 also gets thrown in.
    Maybe I'll try swapping coil 4 & 3 ( maybe this time it really is the coil) and once my friend lends me his spark plug socket, I'll pull the spark plugs to take better pictures.
    I happen to have a smog inspection due very soon - and obviously this will be an issue with passing. On the torque app, the following 3 items say not ready: Evap, o2 and catalyst. If I remember correctly, 2 years ago, car passed even though these weren't ready... does anyone know for certain if these items just aren't read correctly by the torque app? What is interesting is that it says ready for misfire...
  4. Bens04Prius
    New Jersey
    so I pulled coils # 3 & 4 to swap and see if problem moves from 3 to 4 and I found some oily yellow residue on #4 (even though #4 did not come up as misfire..). This oil looks like olive oil - even if the valve cover is leaking, I don't understand why the oil would be so yellow and "clean" looking. Can this be something other than oil?
  5. Patrick Wong
    18,210
    6,517
    Maybe someone spilled engine oil in that area?
  6. Bens04Prius
    New Jersey
    So after swapping coil 3 & 4, it shows pending codes for cyl 1 & 3 (as before) in addition to the p0300 random misfire. Since it seems to not be coils nor the plugs (plugs are relatively new), then I guess I really need to do a good check on the fuel injectors - I did pour in a bottle of techron but over the past 15-20 miles didn't seem to fix the problem. I do understand that there is a possibility of a blown head gasket, or low compression in general, but I'm obviously not going to be spending the money to make those repairs on such a high mileage car. Best case scenario I would try a can of engine restore & a leak stop for the coolant to see how much longer I can keep it going. Its unfortunate that it's much less easy to get access to the injectors or I would have replaced them a while back...
  7. padroo
    padroo Senior Member
    2,763
    2,253
    Those plugs look like burnt oil, if you take them out again make sure you clean the insulators. They don't insulate well when they are contaminated. Just a suggestion. High voltage will take the path of least resistance, don't give it an excuse.
  8. Bens04Prius
    New Jersey
    Yup - I cleaned them really well before putting them back in - with q-tips & everything. The funny thing is that coil #3 was clean, and coil #4 was dirty. After swapping them, I continue to have issues with #3 while #4 is fine...so it does seem in this case that the coils haven't been affected by the liquid. I am also keeping in mind that the liquid may just be water that seeped in through the poorly sealed coil gasket thing (I believe there was a recall/tsb on this issue) as it doesn't smell like oil.
  9. padroo
    2,763
    2,253
    What's next, a compression test, fuel pressure, dirty injector?
  10. Bens04Prius
    New Jersey
    compression test was done about 6 months ago. I'm skeptical about results as I can't say the tester was good (see previous posts) and it did break on me, and dry compression test seemed to show even wear across cylinders... either way I'm trying to eliminate other potential issues before I go for that can of restore or leak seal - the misfire I had did go away (or at least were pretty minimal such that it didn't make the car jump) until last week - so its hard for me to understand why it would have gone away and then came back if it is something as serious as a compression/valve/head gasket issue unless that bottle of techron last time sufficiently cleaned the injectors and they need another cleaning (or a more robust cleaning this time).
    I have also seen "white smoke" from the exhaust, but it has only been when the car was cold in the morning, so I chalked it up to just condensation being burned off like with all cars in the cold. In the past week I've seen it too, but again, if its not firing on some cylinders, my understanding is that the excess fuel is being burned off and this is to be expected (and it is still quite cold here so now 2 reasons for it...).
    Either way, the one thing I never really checked was the fuel injectors... question is whether there is something that is easier to check first...
  11. Bens04Prius
    New Jersey
    how do I check fuel pressure? is there any way to reliably do so via the obd torque app?
    Here is some data logged by the app on my last trip:
    I do wonder if there is anything useful in there...
  12. Bens04Prius
    New Jersey
  13. Bens04Prius
    New Jersey
    so acc to this mode 6, its primarily cyl 3 that is misfiring - other cylinders misfire less than 1% as much = a few times per drive. This would seem to point a specific issue with #3. I will try swapping the spark plug (already swapped coil) and I guess I'll have to go for injector swap as well.
    Previous tests did not seem to indicate that the #3 cyl had lower pressure then the others, so I'm trying to understand why only #3 would be causing most of the problems in the event the issue is not the spark plug or injector - is there anything else that would specifically cause a specific cylinder to misfire? I don't see any residue that makes me believe its the valve cover - could a head gasket failure at cylinder 3 be an issue?
  14. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Here's a cheap injector. http://amzn.to/2Dz3Lpv I just ordered one as I'm chasing down a misfire issue too. It's not hard to get 1,2,and 3 off. I was just looking at my plugs today and ended up pulling the fuel rail off to clean a bunch of crud off them from where someone loosened the valve cover bolts and never re-tightened them. My injector connectors had oil in them. I just thought I'd share, good luck.
    SFO likes this.
  15. Bens04Prius
    New Jersey
    Thanks! for $25 I can surely go for replacing the injectors. Let me know how well these work for you once you install them.
    As an aside, I have another reason to suspect the injectors - a bit of googling says that a bad injector can cause a smell of gas - which I definitely do smell.
  16. Bens04Prius
    New Jersey
    So I just pulled spark plug #3. it was covered in some sort of liquid - smelled liked gas/oil. I wiped it off and stuck it back in, then pulled back out and re-wiped and repeated like 10 times. Turned on car and seems to be running much better - took it around the block after letting it warm up like 10 min, and I'm not getting any misfires and car is much smoother (thought not 100% yet, still hear that kind of "something small being thrown around inside" noise). Is it possible that the whole problem is a leaking valve cover gasket?
    some pictures:
    Inside of cylinder before removing spark plug:
    wet spark plug before wipe off:
    spark plug after wipe off (but didn't yet wipe white ceramic)
    Inside of cylinder with spark plug removed:
    Car was spewing this grey smoke after which diminished as it warmed up:
    https://photos.app.goo.gl/GA6mRMdO5KdfIakq1
  17. padroo
    2,763
    2,253
    Here is a link about carbon tracking. Carbon tracking is basically a high voltage leak.
    Part 3 -Carbon Tracks are a Common Cause of Ignition Misfires
    By moving the coil and the plug to a different cylinder that should eliminate both of them as the cause and you could move further down the list as the cause.
    Bens04Prius likes this.
  18. Bens04Prius
    New Jersey
    So I was lucky enough to pass the smog inspection today. I haven't had misfires in over 80 miles (I believe that the emmissions readiness happened at around 75 miles after clearing the CEL). I also recently realized that the valve cover gasket only deals with oil leaks on the coils side (ceramic part) of the spark plug. If oil is on the interior (spark side) of the plug, does that mean its a head gasket?
  19. Bens04Prius
    New Jersey
    Did your misfire go away after replacing injectors?
    padroo likes this.
  20. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Head gasket leak could cause many different problems but not oil in spark plugs. Burned oil (deposits) on spark plugs just tell that engine is burning oil. That could be cause by bad valve stem seals or piston rings.
