Missing dust deflector after bearing replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AFindlay, Jul 24, 2018.
  1. AFindlay
    AFindlay Junior Member
    Vermont
    When my mechanic replaced my driver-side front bearing he destroyed the dust deflector in order to remove it. He replaced the bearing but did not replace the dust cover, siting that the cover isn't really needed, as it keeps as much dirt in, as keeping dirt out.
    So, I am left wondering if I should accept his reasoning, or should I get a new dust cover installed?
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PRIUSchat!!
    Would the mechanic install the new deflector for no charge?
    m.wynn and Raytheeagle like this.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Driver side what bearing?
    Wheel bearing? Why would the shield be removed?
    Price a new one, and labor, then talk to your mechanic.
    I’m assuming it’s not a Toyota dealer.
  4. AFindlay
    Vermont
    He claimed he could not buy one.
  5. AFindlay
    Vermont
    I should have been more specific. It is the wheel bearing, and yes, this is my local mechanic.
    The videos I have seen of replacing this bearing on a 2007 prius show the mechanic popping of the cover with a screw driver. It looks trivial to do. I assumed it was just to get it out of the way.
    My main concern is how important is it? I am driving around without it right now.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    It keeps all the road debris/water/puddles/mud from getting into your wheel speed sensor. Not to mention VERMONT snow ice salt etc etc etc..............the metal retaining ring has a small cutout that has to be aligned with the speed sensor face so it can see through the retainer and pick up the rotating "star" wheel on the axle assembly. There are no openings in the dust cover, so no debris gets into the "star" wheel or sensor area.
    I've done this wheel bearing (actually a hub assembly) on both sides and know exactly what video you're referencing. I was able to pop the dust covers off no problem. "OFF" is actually a bad term, you actually pop them away from the knuckle and then pull the cover and axle back a bit to access the 4 bolts holding the hub. Doing it this way allows you to swap the hub without pulling the entire knuckle assembly. BUT, you have to be very careful when reinstalling. It is very easy to misalign the metal dust cover retaining ring and damage it. Once damaged, that puppy is NOT going back in place properly.
    Now, if he pulled the knuckle and hub assembly completely off and forgot to put the dust cover back on during reassembly then that's just a matter of pulling it back apart and installing it. There is NO WAY of installing a new one with the axle assembled.
    Part 43246A and B on the drawing.
    FRONT AXLE HUB. For 2008 Toyota Prius | Toyota
    They are available for about 25 bucks each from Toyota
    2008 Toyota Prius Deflector. Front, brakes, bearing - 4324647010 | Toyota
    mmmmmmm.......microphone drops to the floor.......
    #6 TMR-JWAP, Jul 26, 2018
    AFindlay likes this.
  7. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    If your mechanic is smarter than the engineer who designed that part of the car, why is he working as a mechanic? The pay is lower and it is hell on that fresh hands look that is so popular when drinking fine wine in Paris each weekend.
    He needs to put the parts the engineer specified back on the car. If that shield was not needed, Toyota would not have made it and installed it.
    #7 William Redoubt, Jul 26, 2018
  8. ChapmanF
    19,022
    I would obtain the part and install it soon-ish, when the new bearing can probably still be removed without damage and reinstalled (the dust shield goes behind it).
    Wait long enough, and the bearing tends to get very fond of the knuckle it is mounted in, and most of the approaches to forcing it out will damage it, adding the price of another new bearing to the (considerably lower) price of the dust shield. So sooner is better.
    -Chap
    m.wynn and SFO like this.
  9. Brnstrmr
    Brnstrmr Junior Member
    2001 Prius
    is it possible to rotate the dust cover without complete disassembly? TIA.
  10. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    If I remember correctly, iIf the dust cover was installed with the window not completely aligned with the speed sensor, it can be "popped" again rotated as needed and inserted back into position.
    Don't forget to remove the sensor first if you have to mess with the dust shield. It comes out pretty easy. Just remove the single mounting bolt and it should slide right out. Then do what you have to do with the shield. That way you don't risk damaging the sensor face and you can look into the hole to see how well it's aligned.
    #10 TMR-JWAP, Jul 27, 2018
  11. AFindlay
    Vermont
    Thanks for all the responses.
  12. XythAdar
    XythAdar Junior Member
    I have a similar problem with previous mechanic not replacing the dust deflector. Unfortunately I didn't find out until my wheel bearing failed after 2 years.
    Now today I try to put everything back together and my car gives me the ABS VSC etc lights. I pop the tire off again to find that the dust deflector decided to spin with the CV axle instead of staying put (thereby shearing off the tip of the ABS sensor). How do I go about getting that deflector to stay put? do I need to replace the knuckle to get a tighter fit? Previous mechanic certainly marred the front of the knuckle trying to remove the bearing hub last time :/
    Thanks!
  13. TONY12345
    TONY12345 New Member
    vEGAS
    dID YOU FIND OUT HOW TO KEEP THE DUST DEFLECTOR FROM MOVING i HAVE THE SAME PROBLEM.
  14. Txrazor
    Txrazor Junior Member
    Azle, TX.
    I am having this exact same problem, dust shield rotated. .
