Missing fittings in Engine Bay
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Dec 26, 2017.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Hi Guys,
    I have been reading this forum for about 2 months. Got my Prius a few weeks ago (2010 Prius III @140k)
    And this is my first post:)
    I have engineering background. With that, you can say I am totally sold to this Prius. I just love it.
    I have been cleaning and caring for it since the day I got it. Fixed many simple things so far. Engine looks clean and well taken care of. Though I found a few (non-critical) missing fittings in the engine bay. I am a perfectionist and wanted everything to look original. I tried to search for the part numbers through some websites toyota eparts (I cannot post the full link here yet due to some forum rules.)
    I couldn't find it. I am sure it is there somewhere. If some of you can point me where to look for it exactly or if you know the part numbers, I would appreciate.
    The one circled in red must be a simple fitting probably same as the one on the very left.
    I wonder what is the missing one circled in green. Seems like a metal screw but what is it holding there?
    I am attaching a picture here.
  2. Mendel Leisk
    42,343
    Took a look at ours: you're only missing one fastener, at the red circled location. It's a small push-in plastic fastener, same as two others on the same piece. You can pick up at dealership parts dept, though they may need to order it in. Or online, McGeorge Toyota's a good site.
    The green circle is open on ours too, for some other configuration maybe.
    Woodstock74 and bisco like this.
  3. Mendel Leisk
    42,343
    That engine bay looks very pristine btw. A lot of times with posted pics the inverter bright metal is all rusted to hell: cars that have spent their life parked outside in heavy humidity?
  4. iskoos
    415
    254
    Orlando, FL
    Thank you Mendel. If so, then I can just walk into a dealer right down the road and pickup the missing part. I will show them the same picture or just take one of the fastener with me.
    Yes the engine looks clean. It was one of the reasons I bought this car. I have seen many other cars where the engine bay was looking terrible with rusty screws, broken plastic parts and fittings. Walked away...
    This is a Florida car (home of humidity:rolleyes:) and I am the 3rd owner. The car has been taken care of well. She will see her better days with me...(y)
    jerrymildred, Mendel Leisk and bisco like this.
  5. bisco
    52,848
    congrats and welcome! all the best.(y)
  6. Mendel Leisk
    42,343
    Semi-interesting: it looks like the fasteners that are present on that (pictured) piece, are different style than the ones on our 2010. Ours are the kind that you release by prying up the centre cap, whereas those look like the style that you push down the centre to release. Both work I guess.
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Wao! Does it mean you've a gift of detailing? You got to open a detailing shop menh!
    By the way, how did you detail that engine? It looks so cool. A lot of folks always say not to use water in the process.
    Dxta
  8. iskoos
    415
    254
    Orlando, FL
    @ bisco, Thank you...
    @ Mendel, Yes you are right. I had to push the pin all the way in to release and pull the fastener up. But it was a hell to recover the dopped pin from the bottom. A very tight space to work.
    After what you said, I then checked some pictures online and none of those fasteners were looking like the ones I have on my car.
    It is quite possible that the ones I have aren't the original fasteners. This is a very common practice done by some shops. They collect all the screws/fasteners into a tray and then use them as they fit when they are putting it together.
    It seems this plastic trim piece was removed before. I will make sure to get three original fasteners and replace them all in this case.
    Thanks for pointing that out...
  9. iskoos
    415
    254
    Orlando, FL
    Yeah you may say that I am a detail freak. I didn't use water at all. No way on a hybrid car... The engine was very clean when I got it. I just added my touch up:)
    Prodigyplace and Dxta like this.
  10. ChapmanF
    19,019
    Those pins don't have to be pushed so far they fall out. Only far enough to click, and the fastener should pull easily out. Then you just push the pin back up from the bottom, until it sticks out on top. Reinserting the fastener, you push the pin down flush.
    Those are my favorite of the Toyota fastener styles. I keep a spare bag of them around, and I use them in place of pretty much any other style of 7 mm fastener I take out, because the other styles annoy me more.
    -Chap
    jerrymildred likes this.
  11. Mendel Leisk
    42,343
    On mine the fasteners are the pry-up style. I agree those push ones are easy to release, but maybe they're a poor fit, not meant for that. I suspect OP is right, that at some point a body shop or mechanic has switched them.
  12. ChapmanF
    19,019
    I'm using them myself for that very piece, up front under the hood. They fit fine for that.
    They don't have much depth, so sometimes they won't work in an application where three or four layers of something are being clipped together. Still, in most cases where whatever came out was 7 mm ⌀, they've made fine drop-in replacements in my experience.
    -Chap
  13. iskoos
    415
    254
    Orlando, FL
    @ ChapmanF,
    I checked the fasteners again and you were right. The pins didn't have to be pushed all the way in. I was in a hurry and didn't want to spend time (Though in the end, I spent way more time to recover the fallen pins:rolleyes:)
    I will visit the dealer this afternoon and see what part they will offer. I will let you know...
  14. ChapmanF
    19,019
    The nice 7 mm ones with the pushable pins, which are my favorite, are P/N 90467-07117.
    -Chap
    Prodigyplace likes this.
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Welcome to our board! I hope we see more posts from you.
    Check out the sticky thread in this section which has links to the NutzAboutBolts maintenance videos. This is the go-to guide for every known maintenance task of our Gen III cars. We’ve been pushing them for ever-more-complex jobs, such as removing/cleaning the intake manifold and the EGR valve/cooler. But you can begin with some simpler jobs and go from there. I like the spark plug project, because it shows you how to remove all of the cabin air intake, so you can thoroughly clean ALL on the air passage into the cabin, instead of just replacing the cabin air filter.
    I bought a Toyota-made cover for my inverter, and my engine otherwise looks a lot like yours:
    #15 Rebound, Dec 27, 2017
    Raytheeagle likes this.
  16. Mendel Leisk
    42,343
    Pics of ours, I'd assume they're stock. Has a nice, matching pebble texture:
    (You don't want to drop these into the engine bay: then you're jacking up the front end, pulling off the engine underpanel..."
    iskoos likes this.
  17. iskoos
    415
    254
    Orlando, FL
    @ Rebound,
    Thanks for the welcome. You will definitely see more posts from me. I spend time on my cars:)
    I will be doing bunch of maintenance projects. Spark Plug change is in my list. I think they have never been changed. And I know how much I need to disassemble to get to them. (Good and bad...)
    EGR system is also in my list. I will tackle that job and many other as well. This Prius HSD is just fascinating. I will be discovering more of it as the time goes by.
    I see you got a plugin version. That's my ultimate goal. I will definitely be upgrading to a plug-in Prius one day. In the meanwhile, I will drive and learn more about my hybrid...
  18. iskoos
    415
    254
    Orlando, FL
    @Mendel Leisk ,
    Thanks for taking time to post those pictures. I visited the dealer yesterday. The guy wasn't sure of the original fastener. He gave me one at first which didn't fit. I then picked one which I thought the best match and after seeing your close-ups, I am very certain that I picked the correct one.
    It is the left one on the attached image with part # 90467-07211. The outer diameter measures about 19mm (0.75") and the button diameter is around 10mm. If you have some time in your hands and may confirm the measurements with me, that would be great. It is textured just like the one you posted.
    The original ones on my car (same as the one Chap posted 90467-07117) can be seen on the right side of the picture. They are also nice but I think these aren't the original fasteners. I checked many under-hood pictures online and couldn't find them.
    BTW dealer sells each of these clips for $3:eek:. At Amazon, pack of 10 can be purchased for around $14. I just don't need that many...
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    If you do your own work on your Prius you might;).
    I’ve bought a couple of packs over the years and some how they get used:whistle:.
    But having replacements on hand isn’t a bad idea (y).
    edthefox5 likes this.
  20. iskoos
    415
    254
    Orlando, FL
    Do they really use this part at a lot on Prius?
    I didn't do much work on my car yet but the front top of the engine bay was the only place I see it used so far.
