Missing Fuse
Discussion in 'Gen 3 Prius Technical Discussion' started by ImranAs'hab, Jun 12, 2016.
  1. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    Dears..
    As had some free time:), i checked the fuse box under the hod and found that the fuse No. 15 for ECU-B3 is missing..:eek::cry:
    on the manual it say "Air Conditioning System"..(n).. but my AC is workingo_O
    dose any one know any thing about this fuse and what is it for (n)...
    my pree is 2011 with solar panel..
    and One more thing:D.. any one know something for the AC bad smell:confused:.. just like old socks.
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    It may be for remote AC. Does your car have that?
  3. ImranAs'hab
    JORDAN
    Dear len
    that is working too without the fuse.. i wonder what that fuse is for???
  4. douglasjre
    douglasjre Senior Member
    2,247
    751
    Null, NL
    Can I install remote AC if my pri didn't come with it?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Checked your can air filter recently?
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    I believe that fuse was replaced with a fusible link. The topic came up in one of my posts when my compressor failed at 81K in September last year. I asked about that fuse and was told it is now a fusible link.
    The foul smell problem is addressed in numerous posts, given the proper search term. You might have a condensate drain blockage which will need to be cleared from underneath the car. If it is a blockage you can sometimes here water sloshing around when turning corners and braking. If it is not blocked you might be able to eliminate the smell by turning the A/C off (press the A/C button to turn off the green LED) while letting outside air continue to blow through the system for about 5 minutes before parking the car. This will ensure that additional water vapor will condense and flush the evaporator core, drain out, and the evaporator core will dry somewhat. This will reduce the amount of mold or mildew growing in the system. You will have to perform this flush operation for a couple of months maybe. If that doesn't work, then the next step is a chemical flush. There are various products and procedures, and it might be best to trust this to the proper technician. Good luck.
  7. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    My guess is that you might have a different wiring from your fuse box layout info.
    For example, I got the same thing on number 15 as you ECU-B3 and 14 is "no circuit" but here I found that:
    14 is ECU-B2
    15 is no circuit
    and 16 is ECU-B3
    Toyota Prius mk3 FL – fuse box (europe version) | Auto Genius
    Also Air conditioning system is under 15 in the main layout and the "Left side" layout it's second time under 23.
    ImranAs'hab likes this.
