Missing hose clamp?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, Apr 24, 2016.
  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I noticed something recently, on the coolant recovery hose, on one side of the fitting there is a hose clamp, and on the other passengeramp side of the fitting, there is no hose clamp.
    Can you please check your situation and report back? Thanks
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Mine is definitely like that as well
    xliderider likes this.
  3. Mendel Leisk
    42,219
    Me too. There's another location like that, maybe partially hidden by the cosmetic engine cover?
    There was a thread about this a few years back, so I put small airline clamps on the two locations. And then, I read how airplane clamps can cause uneven pressure, possible crack the spigots under the hose, so I took them off. No problems.
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    Thanks for the replies guys, it just seemed really odd. ;)
  5. RRxing
    RRxing Senior Member
    2,561
    1,837
    NEPA
    A little late to the party, but mine looks just like your photo...
  6. CR94
    CR94 Senior Member
    2,811
    1,234
    Northwestern S.C.
    Yes, it does seem odd. They must be depending on tight fit, ribbing on nipples of the Y-fitting, and perhaps adhesive to keep the hose from blowing off. I added a screw-type hose clamp there, not too tight.
  7. Mendel Leisk
    42,219
    Something was said in the old thread, about the hose and the plastic piece having a single part number.
